Results 1 to 5 of 5
Thread: Blower Motor issue
    tallpat's Avatar
    tallpat is offline Cadillac Owners Fanatic
    Automobile(s): 1986 Coupe Deville
    Oct 2006
    Columbia, Maryland, United Sta
    138
    Blower Motor issue
    Hi everyone, Been driving the 86 cdv on a more constant basis an issue has come up that i have heard is a common problem with these cars.My blower motor will not shut down after turning the key off. I discovered this when I came out the next morning to start the car the battery was stone dead
    Did the relay fail? or did the blower motor fail? Is this a difficult repair?
    Thanks for your help in advance.
    69
    82,286
    Re: Blower Motor issue
    I would suspect #12. MODULE. AIR CONDITIONING (A/C) Electric Temperature and Motor Control
    http://parts.nalleygmc.com/showAssem...rimLevel=14344
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Ranger is most likely correct. The power module fails. 30 minute replacement.
  5. #4
    tallpat's Avatar
    Oct 2006
    138
    Ranger, Thanks I do have question these connectors are origina,l there are 2 gray plastic locking pins on either side of the connector I cant budge them without breaking them. Is that ok? I want to temporarly disconnect the power to the motor control module so I wont have to keep disconnecting the battery everytime i go to start the car.
  6. #5
    Feb 2003
    california
    69
    6,688
    They do slide out but yes you can cut them, Then unlock the normal terminal locks and remove.
  • You may not post replies
