regular gas in a 99 deville?
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, regular gas in a 99 deville? in Past Cadillac Vehicle Discussion; I've been using regular in the tank. Could this be causing my P0327 code?...
    jgallo is offline Cadillac Owners Member
    Automobile(s): 1999 deville de elegance
    Apr 2012
    11
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Codes are meaningless without definitions. Always include definitions when posting codes.
    P0327 - Knock Sensor Circuit Low Voltage
    To answer your question, no. Your engine will be perfectly happy burning 87 octane under most driving conditions. Your engine has a very effective knock detection system. In the event detonation did occur, the PCM would compensate before you even knew it.
    What octane you use (even if it was lower than 87) has no effect on the knock sensor itself. The sensor is not an octane sensor, it never comes in contact with the gasoline. It is essentially a microphone, "listening" for the the particular frequency of vibration caused by detonation.
    Your code indicates a problem with the sensor, or a wiring/connector problem.
    Apr 2012
    11
    Re: regular gas in a 99 deville?
    Thanks for your reply. I will check it out.
