Weird Headlight Issue
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Weird Headlight Issue in Past Cadillac Vehicle Discussion; My passenger headlight went out so I replaced it. When I turned the car back on, still out. It does ...
    tabascotk is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    28
    My passenger headlight went out so I replaced it. When I turned the car back on, still out. It does however come on when I lock the car with the key fob. Checked/swapped fuses around and still nothing. What is going on here?
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,740
    Re: Weird Headlight Issue
    Check the connections into the headlight, make sure those are good.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,362
    you should update your profile to include the year and model of your Cadillac -
    68
    81,902
    Quote Originally Posted by CadillacLuke24 View Post
    If the light comes on when he locks the car, the connection has to be good. It has to be more involved than that. Sounds like it may be related to the ignition switch. Does it work with the manual light switch?
  7. Remove Advertisements
