Replaced The Water Pump, Now White Exhaust? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Replaced The Water Pump, Now White Exhaust? in Past Cadillac Vehicle Discussion; I'll check the PCV valve and the TB injectors after work and see what I can figure out. It threw ...
  1. #16
    jessica.elaine is offline Cadillac Owners Member
    Automobile(s): 1989 Deville
    Oct 2012
    32
    7
    Re: Replaced The Water Pump, Now White Exhaust?
    I'll check the PCV valve and the TB injectors after work and see what I can figure out. It threw the oxygen sensor error at me again this morning, too.
  2. #17
    Oct 2012
    32
    7
    The PCV valve is fine, and I didn't get an opportunity to check the injectors last night - won't be able to until tomorrow. However, I did run into a couple of things I'm curious about, and I got a new error code this morning (E12 - No Distributor Signal), so I would like to check that out as well. This is what I've got going on:
    Any thoughts? Also, is fuel injector cleaner something that is safe to use - and would it potentially fix this problem?
  3. #18
    68
    82,076
    Most of us here would not recommend any snake oil additives. They usually do not help.
    Not sure what that is that's bubbling and leaking or what it is leaking, but that can't be good and should be fixed.
    Pooling fuel is a leak and a fuel leak is VERY dangerous. It too needs to be repaired before you run it anymore.
    The part you say you cannot remove is a cover on the distributor. Not sure how it is removed, but your plugs are not under it. The plugs are at the other end of those wires.
  5. #19
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    I'm pretty sure that cover on the distributor just pops off, like a friction fit.
  6. Remove Advertisements
