Results 1 to 5 of 5
Thread: Armrest removal
    DedWrng is offline Cadillac Owners Member
    Automobile(s): 1985 Fleetwood S&S Funeral Coack
    Dec 2004
    Virginia Beach, VA
    56
    49
    Armrest removal
    I've got new window switches to install in the armrest on the driver's side door. How do I get the armrest off to do it without boogering up more than is already broken?
    Dec 2004
    Virginia Beach, VA
    56
    49
    Re: Armrest removal
    I've also yet to figure out how to pull the vent louvers from the dash to remove the dashboard cover without scratching them up. The pictures in the dealer service manual help some, but they assume a certain level of previous knowledge that I'm lacking. I got the cover off, replaced my stereo speakers, and would like to fasten the 4 screws behind the louvers in their proper place.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,476
    Re: Armrest removal
    There are a bunch of posts around for the arm rest. Do a search for it and you should find some that will help you. You just pry the switches out.
  5. #4
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: Armrest removal
    There should be two bolts (maybe three) holding the armrest to the hinge. Take these off, and it comes right out. With the armrest, i believe on the back by the seat controls, there is a notch cut out. You may need to press down on the door armrest padding to see it better. Insert a screwdriver, and push towards the switches. Then they just tilt and lift out.
  6. #5
    Dec 2004
    Virginia Beach, VA
    56
    49
    Re: Armrest removal
    Yes, the notch at the back was the key. My clip was a little bent from previous ministrations by a former owner, so it took much more force than I was willing to inflict on 20 year old plastic without having seen an armrest apart. I solved that problem by going to the local auto recycler and crawling through some stripped Fleetwoods and seeing how they come apart. Removing and reinstalling parts on a junker for practice makes me feel better about mine not joining them anytime soon.
  • You may not post replies
