Water pump drive pulley removal
Results 1 to 7 of 7
Like Tree1Likes
  • 2 Post By Submariner409
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Water pump drive pulley removal in Past Cadillac Vehicle Discussion; Is there a particular procedure or special tool required to remove the water pump drive pulley? The grooves on mine ...
    Vito_1502's Avatar
    Vito_1502 is offline Cadillac Owners Member
    Automobile(s): 1997 DeVille FWD
    Jul 2011
    Clarksville, TN
    57
    10
    QuestionWater pump drive pulley removal
    The grooves on mine melted when the tensioner pulley seized.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,175
    Re: Water pump drive pulley removal
    Yes. You need a power steering pump pulley removal/install tool. Not too many bucks at large parts stores or a NAPA. Metric threads.
    The shroud is held on by 2 10mm nuts and a bolt. The same studs that the nuts come off of hold the tensioner to the water crossover. The tensioner mounting plate is threaded and those studs come out with a 10mm deepwell socket.
    Your engine may still have the protective plastic cap screwed into the end of the cam snout. Unscrew it first. That pulley is pressed on TIGHT and you can't twist or hit the hub - break the cam or ruin the cover seal and you're in for some nasty work. The puller uses the groove in the pulley hub to pull on. The new pulley gets pressed flush with the cam snout.
    Replace the tensioner pulley/bearing - you don't need to replace the whole tensioner. NAPA. New drive pulley - Chris in Parts at Rippy Cadillac over there > or maybe www.rockauto.com
    Pictures and diagrams of all this in my albums - click my username, open the profile. Left column, lower part - 2 albums, 6 pages of Northstar stuff. Your water pump drive is the same as the later engines.
    Vito_1502 and Vito_1502 like this.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    The pulley remover can also be "borrowed" through the rent a tool program at most parts stores.
    Vito_1502's Avatar
    Jul 2011
    Clarksville, TN
    57
    10
    Quote Originally Posted by Submariner409 View Post
    Saw your pics and the special tool (J-38825). A couple of other posts spoke a different tool (J-38816) to install. The puller I got from Autozone won't stay hooked on, so am taking it back and see if I can talked to a "seasoned" clerk who can understand what I'm trying to do.
    Feb 2006
    57,175
    Kicker is, those dedicated GM/Kent-Moore special tools are absolutely stratospheric in price, so we make do with different pump pulley tool sets.
    You could pick up a small 3-jaw gear puller and grind the jaw tips into flats that would fit the pulley hub groove........ if you have a bench grinder. The installer can be jury-rigged at any hardware store - a long proper metric full thread bolt (oiled), stack of greased flat washers and a nut. You offer up the new pulley to the cam snout, screw in the mess of bolt/washers/nut, get things straight, and begin screwing the nut down the bolt: pushes the pulley onto the cam. Hub flush.
    Vito_1502's Avatar
    Jul 2011
    Clarksville, TN
    57
    10
    I saw another post that mentioned Harbor Freight for a puller...and I just happen to have one here in Clarksville. Will see what they have and also consider the grind to fit option as well.
    WHat size (dia/length) would that metric bolt have to be to reinstall the pulley?
    Feb 2006
    57,175
    Don't remember........... will check later or tomorrow.
  10. Remove Advertisements
