90-93 DeVille brake question
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 90-93 DeVille brake question in Past Cadillac Vehicle Discussion; Do all the 90-93 DeVilles use the same front discs?...
    Ghost C's Avatar
    Ghost C is offline Cadillac Owners Fanatic
    Automobile(s): '91 Sedan DeVille Silhouette Special
    High Point, NC
    30
    439
    tracer200 is offline Cadillac Owners Member
    Mar 2004
    Kentucky
    32
    6
    Re: 90-93 DeVille brake question
    Quote Originally Posted by Ghost C
    no, there is a big brake system, and a small brake system, I have a 90 deville an bought rotors, put them on then couldn't get the calipers back on, I was working at Toyota at the time, went to talk to parts manager and he told me about the little and big brake systems on caddilacs, luckily Car Quest switched them out for me, hope this helps
    edit: also there is different size brake pads for the large and small calipers, forgot about that, good luck
    HippieD9 is offline Cadillac Owners Fanatic
    Nov 2003
    Suburb of Chicago
    34
    176
    Really? Do you know the application for the larger brakes? As far as I knew there was only one... I knew of larger brakes for the 87/88 deville, but not the early 90s.
    Thanks,
    Darren
