VATS 99 deville
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, VATS 99 deville in Past Cadillac Vehicle Discussion; Besides not starting, what else should I be seeing if my car doesn't recognize my key?...
    tsgrpr97's Avatar
    tsgrpr97 is offline Cadillac Owners Fanatic
    Automobile(s): 74 Coupe DeVille, 99 DeVille D'Elegance (diamond white)
    Nov 2008
    Pennsylvania
    100
    VATS 99 deville
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Vats disables the fuel pump and starter. If there's a problem, you'll get a security light, a message, and a code.
    tsgrpr97's Avatar
    Nov 2008
    Pennsylvania
    100
    That's what I thought... I just have crank and no start. I didn't hear the fp ramp up, but between the antenna motor and my wife I don't know if I would have heard it anyway.
    After 10 mins. fired right up. It did this once about a year ago. Maybe I'll swap the f/p relay.
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by tsgrpr97
    If it happens again, remove the gas cap, put your ear to the opening, and have a helper turn the key to the ON position. You should hear the pump run for a couple of seconds. Keep in mind that this will only tell you if the pump is running. It doesn't rule out low fuel pressure, and obviously, there are many other possibilities for a no start condition.
    tsgrpr97's Avatar
    Nov 2008
    Pennsylvania
    100
    I can normally hear it, and I'm pretty sure I didn't this time. Even though there was a lot going on and I was late for work, it didn't ramp up.
    Do these have an issue with the wiring harness on top of the tank causing an intermittent f/p?
  8. Remove Advertisements
