2000 deville leaking sunroof
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 deville leaking sunroof in Past Cadillac Vehicle Discussion; Ok, its been raining more than 24 hours. Went to the car, drove around, no leak. Went inside a store, ...
    eagle9 is offline Cadillac Owners Member
    Automobile(s): 2000 deville
    Sep 2012
    11
    Ok, its been raining more than 24 hours. Went to the car, drove around, no leak. Went inside a store, come outside, sunroof is leaking inside the car, looks like from the front passenger side of su roof or the trough area?? What could this be?
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Re: 2000 deville leaking sunroof
    Sounds like the drain tubes are blocked, very common. Do a search here for clogged drain tubes. Both my rear lines were plugged solid
    Sep 2012
    11
    It may be the drain tubes. I ran weed eater line in the front passenger drain. Ran a waterhose, and i get only a couple of specks of water on that front seat, whereas before, it was a steady drip, along with the headliner on that side being wet. So, i hope that solved it.....
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,193
    Down at the lower ends of the 4 drain tubes - near the inner corners of the wheelwells basically under the A-pillars and sail pillars - there are razzmatazz flappers - designed to keep air and bubbling noises from coming back into the cabin. Find each one and massage it - or simply cut it off.
    While you're under the front passenger side, find the A/C condensate drain elbow and clean it out too: Fall weather, particularly in the morning, can be humid as all get-out and the system will pass off a LOT of distilled water.
  7. Remove Advertisements
