Warning lights
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Warning lights in Past Cadillac Vehicle Discussion; I have an '03 Deville and the ABS , BRAKE , and TRACTION CONTROL lights all came on . What ...
    bobstanster's Avatar
    bobstanster is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Apr 2012
    165
    Warning lights
    I have an '03 Deville and the ABS , BRAKE , and TRACTION CONTROL lights all came on . What causes this ?
    Apr 2012
    165
    Warning lights
    redoxy is offline Cadillac Owners Fanatic
    Automobile(s): 03 DHS, 2008 DTS
    Aug 2011
    Edmonton, AB
    33
    148
    Re: Warning lights
    First pull the DTC codes and post them with their definitions
    Check how to in the sticky on this forum.
    It could be anything from bad wheel speed sensor to ABS module etc.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,478
    Re: Warning lights
    ALWAYS start by checking for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Apr 2012
    165
    I will check them but someone looked at them and said it was the ABS module . I will check myself though
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Go to the top of the FWD Deville/Fleetwood page, and read the "sticky" thread on how to pull codes. List any codes you find, AND THEIR DEFINITIONS, here (there's a link within the sticky with code definitions).
    It's likely a failed wheel bearing/hub assembly.
    Sep 2010
    East Boston MA.
    29
    26,325
    You have an identical thread running alongside this one. Please don't double post.
    Duplicate thread:
    http://www.cadillacforums.com/forums...ng-lights.html
    Apr 2012
    165
    Quote Originally Posted by bobstanster
    codes are C1214 and C1248
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,478
    Re: Warning lights
    please help us help you -
    the codes are useless without the DEFINITIONS -
    and we can't memorize them all -
    Apr 2012
    165
    1224. System/solenoid relay coil / contact circuit open
    1248 EBCM turned on brake warning light
    Sep 2010
    East Boston MA.
    29
    26,325
    Is it C1214, or C1224?
    C1214 - System Relay Contact or Coil Circuit Open
    C1224 - Right Rear Wheel Speed Sensor Input Signal is 0
    C1248 - EBCM Turned the Red Brake Warning Indicator On
    Apr 2012
    165
    Quote Originally Posted by MoistCabbage
    It is 1214
    Apr 2012
    165
    It is 1214
    To clarify. It is 1214 and 1248
  16. #14
    Sep 2010
    East Boston MA.
    29
    26,325
    C1214 refers to a relay internal to the EBTCM. You can try inspecting/cleaning the EBTCM connector contacts (follow the steel brake lines from the master cylinder, to the EBTCM. Disconnect, inspect pins/wiring, clean, reconnect securely. Check the ground as well). But the code usually means a bad EBTCM.
  17. #15
    Apr 2012
    165
    What does a new one cost ?
  18. Remove Advertisements
