starter????
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, starter???? in Past Cadillac Vehicle Discussion; hey guys whatzzzuuupp???? last week the caddy would not start, on the first turn of switch, then on second turn ...
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    starter????
    last week the caddy would not start, on the first turn of switch, then on second turn it started up, no further problems until today. same thing this morning...but now i am sitting in a parking lot and it will not start....there ar no codes given other than the ones listef on past posts that have nothing to do with this issue. all dash lights come on and no service engine light...starter??????
    caddy2002deville is offline Cadillac Owners Member
    Oct 2010
    67
    Re: starter????
    i just had a starter go out. same thing no codes. i would just here a click. it seems like a pain to take out but its not to bad if you work on your own cars for simple things.
    May 2011
    macon, ga
    363
    i have no clicking, just dead silence
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    Re: starter????
    the CLICK is the starter solenoid -
    which means power IS getting to the starter -
    so it is likely the problem IS the starter -
    WITHOUT the CLICK - you are NOT getting power to the starter -
    COULD BE -
    bad ignition switch -
    bad neutral safety switch -
    bad relay -
    blown fuse -
    bad starter solenoid -
    etc -
    try this -
    with your foot on the brake -
    ignition ON -
    shift down to 1 - HARD -
    then shift back to PARK - HARD -
    try the starter -
    if that didn't work - try this -
    WITH FOOT ON THE BRAKE -
    ignition to START -
    wiggle the shift lever while in park -
    if that doesn't work -
    try it in NEUTRAL -
    if that doesn't work - turn the key OFF -
    the above procedure is for a possible bad Neutral Safety Switch -
    May 2011
    macon, ga
    363
    Re: starter????
    ok this is what we did, before i got response from basscatt,....we went and jump started it and it cranked up, brought home, andow will not crank, no clicking noise...so we did both procedures that basscatt suggested (if we did correctly) (we = friends),,,,then it did not crank...so i am going to figure Neutral Safety switch????? Where is location and is it easy to fix????
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    Re: starter????
    the neutral safety switch IS ONE POSSIBILITY -
    but it could be several other things also -
    if the car will start by jumping it -
    the problem is probably NOT the NSS -
    and probably NOT fuses -
    I would suspect a bad ground - loose cables - or a bad battery -
    you need to start back tracking power -
    from the starter back to the ignition switch -
    May 2011
    macon, ga
    363
    Re: starter????
    ok we just had to jump it again to start, got it up on ramps,,,,
    May 2011
    macon, ga
    363
    Re: starter????
    ok will start looking for bad wires.....where is starter location...diagram???
    May 2011
    macon, ga
    363
    Re: starter????
    battery is only about 6 months old, but i noticed the other day while riding the voltage was down to 12.8 and i know it is suppose to be at 14.0 or above.....
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    Re: starter????
    starter is under the intake manifold -
    but if it will start with a jump -
    the starter is NOT the problem -
    have the battery LOAD TESTED -
    a brand new battery can be defective -
    check the cables at the battery and the connectors under the hood -
    ground wires are a fairly common problem - try this -
    connect the jumper cable directly from the negative post on the battery -
    to the negative terminal under the hood -
    if the car starts - you have a bad ground somewhere -
    May 2011
    macon, ga
    363
    what??? pls explain further, on connection of battery neg. terminal,,,on vehicle jumping or on caddy???
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    Re: starter????
    oops - forgot your Deville has the battery under the hood -
    the newer ones are under the back seat -
    and have special jumper terminals under the hood -
    so - disregard that part -
    May 2011
    macon, ga
    363
    ok will do...will loom for bad lines, reconnect battery and go from there, thanks for all ur help
  16. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    Re: starter????
    begin by looking closely at the battery connections and the battery -
    if the car will always start with a jump -
    the rest of the connections and parts must be OK -
  17. #15
    May 2011
    macon, ga
    363
    ok thanks bass, will have to look tomorrow ...raining here....question for u, me removing the engine cover did not cause problem????
  18. Remove Advertisements
