starter???? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, starter???? in Past Cadillac Vehicle Discussion; if you mean the "beauty cover" - NO - it is there just to make things pretty - and has ...
  1. #16
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    Re: starter????
    it is there just to make things pretty - and has no other function -
  2. #17
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    ok just thought it may have exposed something
  3. #18
    May 2011
    macon, ga
    363
    ok i cleaned the negitive cable yesterday and had battery tested ( good), but rained all day, so could not complete, there was some corrosion, and the rubber that is around the post looked like it may interfere, so i cut a little nit away
  5. #19
    May 2011
    macon, ga
    363
    Re: starter????
    ok, i cleaned the battery cables and looked at all the grounds i could see, mostly on the front of the engine, had battery tested (good or passed), still will not crank...all lights come on, i hear rear compressor or what i think it is, so any other suggestions......
  6. #20
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Important!!! parking breaks on front lifted so you can get under the car to the starter get a long screw drive I want you to momentarily touch the big nut to the small one. Did it crank? If so your battery maybe good and you have other issues. If not check other stuff? More to come after you reply.
  7. #21
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    Re: starter????
    ah - starter is under the intake manifold -
    can't get anywhere near it from under the car -
  8. #22
    May 2011
    macon, ga
    363
    ok as far as i know the starter is on top under the intake manifold,...,but i need some real help guys, i need this car up and running!!!! any suggestions on what it can be??????
  9. #23
    Dec 2005
    288
    O my bad I don't know what year your car is. but the process is pretty much the same no matter where your starter is located. and if you can't get a screwdriver on it. you can use the remote start switched they are sold at most auto part stores.
  10. Remove Advertisements
