dead battery and will stay running
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, dead battery and will stay running in Past Cadillac Vehicle Discussion; i drove the car last night got up this morning it want crank .i jumped it it started right up.. ...
    old tin man is offline Cadillac Owners Member
    Automobile(s): 92 deville
    Aug 2012
    63
    12
    battery dead?
    i drove the car last night got up this morning it want crank .i jumped it it started right up.. battery needed water i added water ..any ideas
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    What's the battery voltage with the engine off? Preferably after being off for at least 30 minutes.
    It sounds like a bad battery. Have it charged and load tested, replace if necessary.
    69
    82,383
    Re: battery dead?
    Time for a new battery. Especially if it was low and the plates where exposed.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    Re: battery dead?
    if you do need a new battery - check out Walmart -
    GREAT batteries - at a good price -
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Forever West
    26
    5,772
    Re: battery dead?
    Diehards will never steer you wrong. My Dad's had them, and the one that gave him fits was a bad unit, and that one even took an Escalade-full of kids watching a DVD for 20 minutes to discover that.
    The one I have never fails to crank Alexandra up
    mike5514 is offline Cadillac Owners Enthusiast
    Automobile(s): 97sls,09dts
    79
    878
    Re: battery dead?
    Check the cables for white powder loosen and move the bolts on the battery cable connections. Dont know how old the battery is but you cant go wrong with Moist advice. Mike
    Aug 2012
    63
    12
    i drove the car thur night ...i went to start it fri night it would not start i added water to the battery and jumped it it satrted and ran..got up this morn it barely craned but will run a min and cut off. same thing over and over wher do i start
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,143
    Re: dead battery and will stay running
    You must have either a VERY old automotive battery or a marine deep cycle piece. ??? Added water ???
    In any case, it sounds as if the battery is past its useful life OR the alternator/regulator is not charging the battery. Does your car have the capability to display battery voltage in the instrument panel, and if it does, what is the battery voltage at rest, key:ON, and fast idle ??? Otherwise, do the same voltage checks with a VOM set to DC voltage, connected to the positive and negative battery terminals/main feed connectors.
    I combined your threads in order to keep all the battery/voltage problems iun one place.
    cjmeyer is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Dec 2008
    Florida
    51
    75
    Sounds like a dead cell.Have battery checked out to confirm.
  12. Remove Advertisements
