Starting Issues
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Starting Issues in Past Cadillac Vehicle Discussion; I own a '93 sedan deville and I have trouble starting it up at times. It would hesitate to start ...
    Dangerous_Deville93's Avatar
    Dangerous_Deville93 is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Sedan DeVille
    Jul 2012
    25
    23
    Starting Issues
    I own a '93 sedan deville and I have trouble starting it up at times. It would hesitate to start when I turn the keys but eventually will start but the more I turn the car on it would get worse and my lights would dim. My assumption would be a new battery. Any suggestions?
    Darth Mobius is offline Cadillac Owners Member
    Automobile(s): 1995 Deville Concours
    Sep 2010
    32
    74
    Re: Starting Issues
    Hit up a parts store and have them test your alternator and battery. Plus, trouble codes if you have any.
    69
    82,383
    Re: Starting Issues
    Sounds like a weak battery.
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Test battery, alternator, or take to auto store to test, clean cables.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,853
    Re: Starting Issues
    I would recommend checking for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    also check the fuel pump pressure and Fuel Pressure Regulator -
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    Re: Starting Issues
    When you say it hesitates to start, does it crank slowly, or even hesitate when cranking?
    If the battery and alternator check out okay, your starter may be dying.
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    34
    1,498
    Have checked your plugs wires and cap or battery cables
    Jul 2012
    25
    23
    Re: Starting Issues
    I checked my battery with my multimeter and it came out fine. It won't start period and the lights dim when i turn the key. I changed my spark plugs a couple of weeks ago.
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    45
    1,845
    Re: Starting Issues
    When you say it won't start, does it crank? or do nothing but dim the lights?
    Jul 2012
    25
    23
    Re: Starting Issues
    It doesn't crank at all and the lights dim when i turn the key. My friends say it's my starter but I'm not sure.
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    45
    1,845
    Re: Starting Issues
    That's where my vote is as well.
    Replacing the starter is not too bad on the 4.9. I've done mine recently.
    It's easiest if you jack the car up to where you can access it from both below and above.
    There are 2 shields to remove below, 2 wire connections (from above), and 2 bolts holding the starter. disconnect the wires before you remove the mounting bolts.
    69
    82,383
    Re: Starting Issues
    Exactly how did you test the battery?
    Apr 2007
    san diego
    34
    1,498
    I'm thinking ignition module
  16. #14
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    45
    1,845
    Re: Starting Issues
    If it were the ICM, the car would still crank, but would not fire.
    The OP is not getting any cranking action.
  17. #15
    Jul 2012
    25
    23
    Re: Starting Issues
    What does ICM and OP stand for?
  18. Remove Advertisements
