Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Starting Issues
  1. #16
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    Re: Starting Issues
    ICM - Ignition Control Module
    OP - Original Poster (you)
  2. #17
    Crudsturbo is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Seville STS & 1991 Sedan Deville
    Jul 2012
    Richmond, VA
    40
    181
    Re: Starting Issues
    Dont let people confuse you take starter off and test it. If you dont know how a parts store can test it for you.
  3. #18
    Dangerous_Deville93's Avatar
    Dangerous_Deville93 is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Sedan DeVille
    Jul 2012
    25
    23
    Re: Starting Issues
    News update: I charged my battery for a good couple of hours and it struggled it crank but after holding the key on it eventually cranked and started. My cousin whose also a mechanic told me my starter is dying which is causing it not to crank up fast. He installed his battery in my car and my car started with the same hesitation to crank but it was easier than with my battery. Would I need both a battery and starter? Any suggestions?
  4. #19
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    Re: Starting Issues
    POSSIBLY -
    the very FIRST suggestion was to have the battery tested -
    your response was:
    I checked my battery with my multimeter and it came out fine.
    that led us to believe
    1) you know HOW to test a battery -
    2) the battery tested to be OK -
    your responses now lead me to believe that you didn't LOAD TEST the battery -
    but simply discovered 12 volts with your multi-meter - and you assumed it was OK -
    if this is correct -
    you need to take the battery to any large auto parts store -
    and ask them to LOAD TEST the battery -
    if the battery doesn't maintain 12 volts while under a load -
    it will need to be replaced -
    a DRAW TEST on the starter will test how much current it takes to crank the engine -
    if the starter draws too much current - it will need to be replaced -
  5. #20
    Jul 2012
    25
    23
    Re: Starting Issues
    Would I be able to test my battery without taking the car?
  6. #21
    Jul 2012
    25
    23
    Re: Starting Issues
    I took my starter to get tested and it passed but it still had trouble cranking, even with my cousin"s battery which still turned the car on.
  • You may not post replies
