No inside lights
Results 1 to 5 of 5
Like Tree1Likes
  • 2 Post By basscatt
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, No inside lights in Past Cadillac Vehicle Discussion; How do i regain door and inside lighting in the interior of my 2003 Cadillac Deville? I have no lights ...
    Fred Lack is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Deville
    Sep 2012
    Vista, Ca
    40
    1
    No inside lights
    How do i regain door and inside lighting in the interior of my 2003 Cadillac Deville? I have no lights when i open my car door.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,895
    Re: No inside lights
    Moved to FWD
    68
    81,897
    Start by pulling the DTCs and checking the fuses.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Have you tried opening a door other than the drivers door?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,362
    if all the fuses are good -
    can you manually turn each courtesy light ON and OFF -
    does the manual dimmer/light switch turn on the interior lights -
    if not - it could be a defective headlight switch -
    do the twilight automatic headlights work properly?
    ENTRY LIGHTING is tied into the light sensor -
    and will only turn on the interior lights when it is dark outside -
    interior lighting is discussed starting on page 3-19 of your Owners Manual -
    and fuse locations are on page 5-94
    in the event you don't have an Owners Manual -
    or would like a copy to keep on your computer -
    go here for a FREE down-loadable copy -
    http://www.manualowl.com/am/Cadillac...lle/Manual/216
    Sean Ab and Sean Ab like this.
  8. Remove Advertisements
