Engine Coolant Hot
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Engine Coolant Hot in Past Cadillac Vehicle Discussion; I have a 95 caddy deville. While Im driving this morning, I turned on the heat and got a message ...
    5hundred is offline Cadillac Owners Member
    Automobile(s): 95 deville
    Sep 2012
    1
    Engine Coolant Hot
    I have a 95 caddy deville. While Im driving this morning, I turned on the heat and got a message that said, "ac compressor off, engine coolant hot, idle engine". I turned of the heat and the message went away after a couple of minutes. Does anyone know why this happened?
    68
    82,063
    Re: Engine Coolant Hot
    Have you checked the coolant level?
