Coolant level sensor location
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Coolant level sensor location in Past Cadillac Vehicle Discussion; Hi, Coolant level is correct ( half of surge tank) but I get the "check coolant level" message Need to ...
    StarLimos is offline Cadillac Owners Member
    Automobile(s): Stretch Deville
    Sep 2009
    Paris, France
    40
    6
    Hi,
    Need to find the level sensor to test it, but was unable to locate it.
    Would someone know where it is? Car is a 2000 Deville "Y" engine Northstarwith limo conversion option.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,188
    Re: Coolant level sensor location
    The sensor is a reed switch in a receptacle in the bottom of the coolant reservoir. Snap-in. Check the electrical connector, or the magnetic float itself may be stuck down for some reason. Once in a while removal and a thorough cleaning of the tank frees things up.
