OLM self reset
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, OLM self reset in Past Cadillac Vehicle Discussion; Y oil life monitor keeps resetting. When I got the car it worked fine. I had the first oil change ...
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    OLM self reset
    Y oil life monitor keeps resetting. When I got the car it worked fine. I had the first oil change done at the dealer and now it keeps resetting. I have never noticed when it does because I don't watch it but today I did the TPMS relearn and then after that it reset.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,168
    Re: OLM self reset
    Which OLM - engine oil or transmission fluid ? Have you disconnected the battery (although that should not cause resets) ? Curious - engine OLM should follow your driving pattern while transmission OLM should remain at 100 or 99 % forever (unless you overheat the fluid).
    Is there any further info in the Personalization section of the owner's manual - or in the oil maintenance section ?
    13ir14314's Avatar
    Jan 2012
    Minnesota
    22
    443
    The engine oil is the one that keeps resetting the trans stays at 99. I haven't found anything in the manual for it and there can't be any way for the oil to go from 99 to 100. I'm not sure how many times it has reset but it stayed at 99 for a long time until today when I did the TPMS learn. I have not disconnected the battery and it is a good battery.
    Feb 2006
    57,168
    Re: OLM self reset
    If you call up the engine (or transmission) OLM and hold the INFO RESET button for 6 - 8 seconds it will go to 100%.
    The kicker is that your OLM seems to be resetting itself to 100% at random times/occurrences.
    Have you seen any weird data codes or voltage hiccups in your car's built-in code scanner system ?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,867
    Re: OLM self reset
    I was going to suggest checking for codes -
    I would sort of expect several "U" codes with those symptoms -
    if there are any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    the other thing you can try is to remove BOTH of the battery cables -
    and hold them together for at least 30 seconds -
    what this accomplishes is - sometimes the memory
    in various modules gets messed up -
    and this procedure clears - or resets the memory -
    it MAY work - maybe not - but it won't hurt anything -
    13ir14314's Avatar
    Jan 2012
    Minnesota
    22
    443
    Re: OLM self reset
    U1000 - Class 2 Communication Malfunction
    U1016 - Loss of Class 2 Communication with VCM
    U1713 - Loss of Front Door Module to Window Motor High Speed Comm.
    U1714 - Loss of Front Door Module to Window Motor Normal Speed Comm.
    I have also had a problem with the radio since I bought the car where it won’t show the call letters but yesterday I FF a tape and when doing that it switch to the radio temporarily as it should but while doing this the call letters suddenly worked. I stopped the tape when to radio and nothing. Would touching terminals together fix this? I have made a thread about this in the audio but no luck.
    69
    82,393
    Re: OLM self reset
    I doubt that touching the battery terminals together will help the radio, but like Bass said, can't hurt to try.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,867
    Re: OLM self reset
    clear all the codes first - then try the cable trick
  11. Remove Advertisements
