2000 Deville leaking oil FAST
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 Deville leaking oil FAST in Past Cadillac Vehicle Discussion; I bought this car a few months back. Never had any problems except, what appears to be a miss in ...
    RickeyParks is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Sep 2012
    6
    Unhappy2000 Deville leaking oil FAST
    I bought this car a few months back. Never had any problems except, what appears to be a miss in the idle. This morning I took my wife to work, and when I got home I notice a puddle of oil in my driveway. Then I looked underneath the car and it was slowly pouring oil out. When I turn the car off, it stops dripping. It drives fine, but wont if the oil runs out!! It does not leak or drip when the car is off. Just really want a good mindset going into a Repair shop. I don't want to be tested by my money amount. I'm sure the transmission will have to pulled as I've read. Just wondering if anyone knows what seal just gave out? Thanks a lot, Rick.
    Sep 2012
    6
    Re: 2000 Deville leaking oil FAST
    Just started doing this TODAY. Yesterday there were no leaks! I moved my car several times and never saw a drop yesterday. But today, when started only, it streams oil out. Hopefully I can get a response soon Im kinda panicking because I don't know any Repair shops by quality of work/rates. Just want to make sure I pinpoint this leak and STOP IT!
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Approximately where is the oil leaking? Right front? middle? rear?
    Sep 2012
    6
    Think I figured out whats going on....I've been looking at the Oil Life Percentage(%) I assumed there was a tiny leak so decided to add 3 quarts of oil. TOO MUCH OIL, lol. Changing the oil right now. I'll post and let you know. If putting too much oil could bring some hazards, please inform me!! I just put the oil in last night, and drove only 5 miles or so this morning. I drained oil and got an entire oil pan FULL! There is still oil in there as well! Only a quart low! Crossing fingers! Cadillac is the BEST if this isnt a seal!!
    Sep 2012
    6
    My oil life was a 57% when I put the oil in it last night.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Adding too much oil can cause the crankshaft and connecting rods to come into contact with the oil in the pan, and froth/aerate it. "Oil foam" is not a good lubricant, and the oil pump can't pump it. VERY bad. NEVER add any fluids to your car, without first checking the current level.
    Correct oil level is half way up the hash marks on the dipstick (xxxxxXxxxxx), 7.5 quarts from empty with an oil/filter change.
    Your Oil Life Monitor has absolutely nothing to do with oil LEVEL. It does exactly what its name implies: monitors the remaining oil LIFE.
    I would suggest reading your owners manual, cover to cover, twice. Then go up to the black tab at the top of the page, and click on Cadillac Technical Archives. Read the ENTIRE page, LOTS of good information, including info on the OLM system, and oil consumption.
    As asked above, where is the oil dripping onto the ground?
    After noticing the puddle, did you at any point check the oil level with the DIPSTICK? Are you sure it was engine oil on the ground?
    BTW,
    68
    82,063
    As MC said, you are confusing oil life remaining (%) with oil quantity. When you get 2 qts low (about the time the oil drops off the end of the dipstick) you'll get a CHECK OIL LEVEL message. Now that you changed the oil, don't forget to reset the oil life remaining to 100%.
    Sep 2012
    6
    Phewwww! Just too much oil and the filter was pretty loose! Running like a BEAUTY now, just like Cadillac should So relieved! Been running an hour, no DRIPS! Thanks for the advice I will defiantly invest some time in doing so!
    68
    82,063
    Can't help but wonder where the oil was coming from, unless it was the loose filter.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,202
    RickeyP, Call up the oil life (OLM) in your dash and hold down the INFO RESET button for 5 - 7 seconds. The percentage will go to 100%. You can safely drive until it reaches 0 - 10 %, then do an oil/filter change using exactly 7.5 quarts of whatever 5W-30 oil floats your boat.
    Here's your dipstick and the proper oil level with 7.5 quarts in the engine:
    <=== ADD XXXXXXXXXX OPERATING RANGE ============oo=============================O
    As posted, when the level just drops from sight at the tip of the stick the engine is 2 quarts low. If you try to keep the level at the top X you'll see increased oil consumption. Read the entire Cadillac Technical Archive up ^^^ in the top black bar, especially the articles on the OLM, oil consumption, coolant, and "Occasional full throttle operation is good ..................".
    If you want more info on your engine and parts, click my username, open the profile; left column, 2 albums, 6 pages of parts and engine stuff for the 2000 and later Northstar.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,751
    Quote Originally Posted by RickeyParks View Post
    Glad to hear it was an easy fix. When you change the oil, get the filter nice and snug WITH YOUR HAND. That is more than enough. Using a filter wrench will make it a royal PITA to get off next time.
  14. Remove Advertisements
