1998 Deville Cruise Control Problems
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1998 Deville Cruise Control Problems in Past Cadillac Vehicle Discussion; I replaced both switches under the brake pedal because I thought that was the cause of my cruise control not ...
    MATTYL88 is offline Cadillac Owners Member
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    33
    I replaced both switches under the brake pedal because I thought that was the cause of my cruise control not engaging as it was working intermittently. This has not solved the problem, even after trying to adjust the switches themselves. What other components make the cruise control work? Sometimes my cruise works, sometimes not. My Dealer says they think I have a bad module but Cadillac discontinued the part. Is this the one by the left fenderwell? Any part numbers available or pictures of the various components? I looked on ebay for used and there seems to be a lot of $50 units or so. Also, what would be the average time to replace parts?
    Any help is appreciated!
    69
    82,287
    Re: 1998 Deville Cruise Control Problems
    Aug 2012
    33
    I appreciate the link to the drawing. What usually craps out first----the box itself?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,706
    I had to replace the module - the "BOX" - on my '95 -
    depending on you skill level - around 10 minutes -
    if you have a pull-a-part salvage near you -
    the part is probably $5 to $10 -
    Aug 2012
    33
    Cost me $30 on ebay but everything works now. Thanks to all for the advice-----it works!
  8. Remove Advertisements
