Dash says Service RIDE SYSTEM
Results 1 to 13 of 13
Like Tree1Likes
  • 2 Post By MoistCabbage
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Dash says Service RIDE SYSTEM in Past Cadillac Vehicle Discussion; What does this mean? How can I fix it??...
    CranberryConcours is offline Cadillac Owners Member
    Automobile(s): 1998 Deville Concours
    Jan 2012
    31
    18
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,117
    Re: Dash says Service RIDE SYSTEM
    Your car has a built-in trouble code reader/scanner. Study the OBD-II (OBD-2) section of the sticky post ^^^ "How to pull codes". Get any codes stored in the system and whether each is Current or History. Write it all down and go back to the sticky to open the link with "obd2" in the address - that takes you to a Master Index of all P,B,C, and U codes. Write down the definitions of any codes found and post it all here. Your CVRSS/RSS faults will set C codes..............
    http://myweb.accessus.net/~090/dtcobd2.html
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,843
    your struts and shocks are electronically controlled - one or more have failed -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Jan 2012
    31
    18
    C1787 - Damper Control Relay Short to GND
    This is the code that I got. Can anyone elaborate?
    Jan 2012
    31
    18
    It also says it is current
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Try swapping or replacing the damper relay in the under seat fuse box.
    Jan 2012
    31
    18
    do you have to take the seat out? which seat is it under? Thanks
    Sep 2010
    East Boston MA.
    29
    26,323
    It's under the rear seat bottom, drivers side. Grab the front edge of the seat bottom, and pull straight up, do this on both sides.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,843
    STOP -
    the rear fuse block is in the trunk - NOT under the rear seat cushion
    Jan 2012
    31
    18
    where at in the trunk?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,843
    Quote Originally Posted by CranberryConcours View Post
    all the fuse information is in the Qwners Manual - starting on page 6-58 -
    if you don't have an Owners Manual -
    go here for a FREE down-loadable copy -
    http://www.manualowl.com/am/Cadillac...lle/Manual/194
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,763
    Open the trunk. Look into the trunk. At the front of the trunk, there's the wall between the trunk and the rear seat. This is a removeable panel. Reach up on the roof of the trunk, and you will feel 4 fasteners along the edge of the roof. Release these to remove the panel. Once you've removed the panel, the fuse block is on the bottom left of the front trunk wall.
    Sep 2010
    East Boston MA.
    29
    26,323
    Sorry. I'm thinking '00+.
    basscatt and basscatt like this.
  16. Remove Advertisements
