Digatal Dash Shows Blank
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Digatal Dash Shows Blank in Past Cadillac Vehicle Discussion; I have a 1995 cadillac deville with digital dash. My digital dash went blank and I tried replacing the headlight/dimmer ...
    tomco14 is offline Cadillac Owners Member
    Automobile(s): 1995 Deville Sedan 66000 Mile
    Feb 2012
    8
    I have a 1995 cadillac deville with digital dash. My digital dash went blank and I tried replacing the headlight/dimmer switch, which did not help.
    When I hold either the Econ Button or the Defog Button in the dash will display everything as normal, as long as I hold the button in.
    What should I look for next??
    Thanks in advance for any help
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Sounds like a bad cluster to me.
    frostycadillac is offline Cadillac Owners Member
    Automobile(s): 1968 DeVille, 1985 Seville, 1990 Deville, 1994 Deville,
    Oct 2009
    Tampa, Florida
    56
    43
    Re: Digatal Dash Shows Blank
    If there's a problem with the cluster, your computer should display the code related to it. Hold the off and lo buttons down and post the code here.
    Feb 2012
    8
    I checked the codes and the dash shows no codes, when it gets to the end it shows PCM?
    Does this mean anything ?
    Thanks
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    PCM? just means it is done displaying codes and is asking if you want to go into the PCM diagnostic mode.
    When you say there is no display, is it completely blank, or does the speedometer and shift indicater only show?
    Oct 2009
    Tampa, Florida
    56
    43
    BigM is correct, the computer is done searching for faults. If no faults exsist, I would think there may be a bulb problem. There are codes for the cluster, lights and other displays. I will pull out the GM manual and check on this for you this evening. As much as I'd like too, I can't carry that thing around with me ...esspecially at work !
    Feb 2012
    8
    The entire dash is blank, the only light is in the radio
    I didn't mention that I had a new fuel pump put in the week before this happened, as I didn't think that
    should have any bearing on this ?? Would it ???
    Thanks
    Oct 2009
    Tampa, Florida
    56
    43
    Ok, the IPC controls the dash cluster. The manual suggests to disconnect the IPC from under the dash, which is located behind the rear seat through the trunk. But before you do this, try pulling these three fuses. A5-IPC (Ign) and B5-IPC (Batt) from the rear compartment fuse panel located in the trunk and A3-IGN1 fuse from the engine compartment fuse panel. Any of these fuses blown will cause this problem.
    Feb 2012
    8
    I replaced all three fuses with new ones, but still no lights
    It will come on sometimes and stay on for while and than go blank again
    Is the IPC unit something that I can replace, or I just need to unplug and reset?
    Thanks
    Oct 2009
    Tampa, Florida
    56
    43
    The IPC can be reset by unplugging it, but I suspect your problem may be worse. Read this thread link, it's petty envolved, not sure I could do this or not.
    http://www.cadillacforums.com/forums...ideas-how.html
  13. Remove Advertisements
