brake pedal goes to the floor
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, brake pedal goes to the floor in Past Cadillac Vehicle Discussion; hello, i own a 2004 deville (DTS Model) and my problem is that my brake pedal goes to the floor ...
    Nutbuster's Avatar
    Nutbuster is offline Cadillac Owners Member
    Automobile(s): 1980coupe(diesel), 1989deville, 2004escalade, 2004dts,
    Aug 2012
    41
    8
    hello, i own a 2004 deville (DTS Model) and my problem is that my brake pedal goes to the floor during braking. i have replaced rear pads, front pads were within spec as were all 4 rotors, brake fluid is always at level as well. could a cadillac man get a few suggestions? thank you all in advance.
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,625
    Re: brake pedal goes to the floor
    Master Cylinder
    68
    81,891
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,358
    yep - the master cylinder is leaking internally -
    if you replace it yourself -
    be sure to bench bleed the new master before installing it -
    if you don't - you will NEVER get a good/hard pedal
    Nutbuster's Avatar
    Aug 2012
    41
    8
    thank you all, will replace it on payday
  8. Remove Advertisements
