Water Pump Housing Crossover.
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Water Pump Housing Crossover. in Past Cadillac Vehicle Discussion; Has anybody had the experience of doing the seals on this? It's a 99 Cadillac Deville...
    4T80e is offline Cadillac Owners Member
    Automobile(s): 99 Cadillac Deville
    Sep 2012
    11
    68
    82,063
    Re: Water Pump Housing Crossover.
    Yes, several people have done it. It's a bitch of a job. You might find a tutorial in the Tech Tips section. If not, then do a google search. Something like "crossover manifold>cadillacforums".
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Time consuming and tedious. Limited space to work in, the section on engine compartment wiring harness that straddles the transmission is constantly in your way, and keeping all 8 bolts and 4 gaskets in place on the crossover while you guide it back into place is.....not fun.
    If you decide to tackle it yourself, remove as many parts from the surrounding area as possible, have an assortment of socket extensions and universal joints handy, and BUY YOURSELF A SLIM, REVERSIBLE, FLEX HEAD RATCHETING WRENCH for the crossover bolts. 13MM IIRC.
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    I just did it last year. It is a tight space and very time consuming but I thought it was fun.
    Sep 2012
    11
    I didn't have anything leaking from my car almost 50,000 miles ago, I understand its old and things fail due to age.
    Since then Ive don't the Radiator, Overflow Tank, Thermostat, Water Pump Seal was leaking badly awhile ago, Heater Pipe under Throttle Body and that's when I discovered the Crossover was leaking at the Cylinder Head at the rear and couldn't see the connection to the block.
    It appears to be going from one area to another
    Going to tackle it this weekend. Saturday and Sunday should be enough time to tackle it (fingers crossed)
    Got the Green Hoses also.
    Sep 2010
    East Boston MA.
    29
    26,325
    Just noticed your username. Never seen someone use a transmission designation.
    Good luck with the crossover job. Let us know how it turns out.
  9. Remove Advertisements
