91 Cadillac Sixty Special
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 91 Cadillac Sixty Special in Past Cadillac Vehicle Discussion; So I've had my Sixty sitting for a while and when I went to start it, it ran fine. But ...
    nsharma1999's Avatar
    nsharma1999 is offline Cadillac Owners Fanatic
    Sep 2005
    54
    168
    So I've had my Sixty sitting for a while and when I went to start it, it ran fine. But when I tried to shift it into gear the lever would not move... I disconnected the linkage at the transmission and can move the shifer at the tranny by hand but still can't move the lever in the car. Can someone tell me whats going on here. There's no issue turning the key in the ignition and it shifted fine the last time I started it 5 months ago. I'm at my wits end.
    69
    82,272
    Re: 91 Cadillac Sixty Special
    Isn't there a shift interlock solenoid that requires you to have your foot on the brake to unlock the shifter? Maybe a bad switch, fuse or connection.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    It sounds like the solenoid on the column. You might not be getting power to it when you step on the brake pedal. Check out this diagram to see the flow chart. Check fuse, power through PRNDL in Park, Brake applied, power to interlock solenoid.
    Sep 2005
    54
    168
    Thanks guys. I will check the shift interlock tomorrow.
  7. Remove Advertisements
