garage door opener/ homelink transmitter
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, garage door opener/ homelink transmitter in Past Cadillac Vehicle Discussion; my 03 deville does not have the garage door opener / home link transmitter option, the little plate were it ...
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    57
    383
    my 03 deville does not have the garage door opener / home link transmitter option, the little plate were it goes pop,s right out, if i were to get one from another deville and popped it in will it work???
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,659
    Re: garage door opener/ homelink transmitter
    Yes it will work... done it many times its plug and play. Make sure you get a transmitter with an amber light if you have a rolling code door opener.
    Go to post #7 in the thread below for the installation and programing PDF file instructions from GM.
    http://www.cadillacforums.com/forums...-homelink.html
    69
    82,190
    I think it will.
    EDIT:
    Oops, 00 Deville beat me to it.
    Sep 2011
    57
    383
    Quote Originally Posted by 00 Deville View Post
    when removing one from a car are there any trick,s or tip,s on doing so??? i dont want to crack or break anything
    00 Deville's Avatar
    Mar 2004
    Wilmington, NC
    52
    2,659
    Just gently pry it out with a small flat tip screw driver.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Here are 3 different type, not sure if they will fit in your overhead. There is a locking tab on the bottom side that holds it in. All of these in the picture are upside down.
    00 Deville's Avatar
    Mar 2004
    Wilmington, NC
    52
    2,659
    The one's pictured on the right are the type that came from the factory in the 00-05 Deville. The amber light model is for a rolling code opener the red light model is for the older non-rolling code openers.
  10. Remove Advertisements
