Traction problem
Results 1 to 15 of 15
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Traction problem in Past Cadillac Vehicle Discussion; Hello my friend over there I have a traction problem in my 1997 Deville, It is like the traction will ...
    joivill is offline Cadillac Owners Member
    Automobile(s): Fleetwood 1976 , Eldorado 1983, DeVille 1997
    Apr 2010
    61
    38
    Traction problem
    Hello my friend over there I have a traction problem in my 1997 Deville, It is like the traction will not go of and the yellow light (two ) light in the control panel " Traction Control and ABS lock"
    and will not go off and the button for the Traction control not wotk, I have a two code currently, IPC U 1255 and AMC U 1315 other are a history, can some one have some ansvear .
    Thanks Johann Vilhjalmsson in Iceland
    68
    81,913
    Re: Traction problem
    Are you SURE there are no "C" (chassis) codes?
    Apr 2010
    61
    38
    Hi I go over this again and find two more codes ot is TCS C 1236 and C 1277 do it sow something ?
    68
    81,913
    Always post the code definitions along with the codes. No one has them memorized. You want the OBDII link in the DTC sticky.
    Apr 2010
    61
    38
    Thanks how can I find it?
    Johann
    68
    81,913
    Go to the red DTC "sticky" at the top of the forum page.
    Apr 2010
    61
    38
    C1236 - Low System Supply Voltage
    C1277 - Requested Torque Signal Circuit Malfunction
    I find this, I know the battery is not good , is it maby the fault just change battery.
    Johann
    Apr 2010
    61
    38
    Johann
    68
    81,913
    Yup, I'd suspect the battery. There is a LOT of electronics in these cars and low voltage wakes up the gremlins to come out an play and wreak havoc.
    Apr 2010
    61
    38
    Thanks for your good helpe Ranger I try to put a new battery ,what is the normal voltage I shall read
    Johann
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,740
    You should get at least 12.6 volts with the key in the OFF position, and 13.6-14 with the key in the ON position.
    Apr 2010
    61
    38
    I have 12,1 in off and when I start the car I have 14,1 volt but I have see it 13,8
    Jul 2010
    Wyoming
    26
    5,740
    the 12.1 at off is on the deathbead. If it were MY battery I'd replace it.
  16. #14
    68
    81,913
  17. #15
    Apr 2010
    61
    38
    Hello again and thanks for your help, what I do yesterday I clear all code out , this morning I drive 150 km and all is ok no yellow signal light and volt meter show 14,1 volt when I driving.
    Hope it will be o.k next time I will bay a new battery
    Johann
  18. Remove Advertisements
