check coolant level light on since changing coolant
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, check coolant level light on since changing coolant in Past Cadillac Vehicle Discussion; In my 2002 Cad SDV, I changed the coolant and since then the 'check coolant level' light comes on now ...
    mutz is offline Cadillac Owners Member
    Automobile(s): 1996 and 2002 Cadillac SDV
    Dec 2007
    Toronto Canada
    74
    In my 2002 Cad SDV, I changed the coolant and since then the 'check coolant level' light comes on now but before changing the coolant it didn't come on. I'm thinking it's an air pocket in the system, but the temperature gauge reads normal, the heater blows hot air like it normally does. The level is down two and one-half inches as per manual, in the overflow tank. I check the return line that runs across the engine is flowing freely. If it's an air pocket how do i get rid of it? Do I need to reset the 'check coolant level' light? While the light was on, I touch the 'info reset' button but it didn't do anything. Any suggestions, thanks!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,202
    Re: check coolant level light on since changing coolant
    An "air pocket" would have nothing to do with the coolant level float and reed switch in the bottom of the coolant reservoir.
    Is the connector at the bottom of the reservoir clean and properly "connected" ? There is no way to "clear" the light, but you might fool with jumping across the connector terminals on the wiring harness plug. See if the light goes on/off - it's only a simple on/off reed switch. If the float is "sunk" or stuck down, or the reed switch has failed (unlikely) then you might be in the new reservoir business - Amazon, automotive.
    Here's the connector pin-out for a 2002 Seville - probably close to yours.............
    68
    82,063
    Also the system is self purging, so as long as the purge line is clear, there is no "air pocket".
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Your float might be stuck - try gently tapping the reservoir. Happens every time when I drain the coolant in my Seville.
    68
    82,063
    You might also try removing the surge tank, fill it with clean water and shack vigorously. If the float is stuck, that may loosen and clean it.
    Dec 2007
    Toronto Canada
    74
    Thanks for the quick answers, I guess I don't have too much to worry about since it will self purge, pehaps the float is stuck.
    PineyJustice is offline Cadillac Owners Fanatic
    Automobile(s): 2001 deville base, 2008 dts
    Apr 2012
    Michigan
    27
    310
    I wouldn't be comfortable bridging the switch because a future low coolant issue would go unnoticed until major overheat occurred.
    Isopropyl alcohol or windex would probably be good for unsticking the switch, the idea would be to dissolve any deposits and not leave any residue.
    Just make sure you rinse it out very well after.
  10. Remove Advertisements
