1994 Deville tranny...what possible causes?
Results 1 to 2 of 2
Like Tree1Likes
  • 2 Post By 98eldo32v
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1994 Deville tranny...what possible causes? in Past Cadillac Vehicle Discussion; What is a best guess what is the cause of this? http://boise.craigslist.org/cto/3245177100.html Thinking about looking and if the car looks ...
    keumnam is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Sixty Special, 1993 Buick Roadmaster Limited
    Jun 2011
    64
    100
    Thinking about looking and if the car looks good overall, offering them $450 and see what it is all about
    Thoughts?
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Re: 1994 Deville tranny...what possible causes?
    Low trans fluid, fluid could need changing, internal transmission issues. Could be in limp mode....
    I personally can't stand transmission issues. I'm on the tail end of a trans swap in my 00 deville. I should have followed my first instinct and swapped the trans when I saw the "service transmission" message on the driver info center. Nope, fixed to some degree, only to have a 800-1200 third clutch housing axle shaft leak.
    I pray that this unit is good, but unless you like slinging 400+ pounds of front wheel drive transmission around without the proper tools to do the job, stay away from that one unless you have someone to replace it cheap.
    maeng9981 and maeng9981 like this.
