Help please! what happened to this pushrod? 4.9
Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Like Tree2Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Help please! what happened to this pushrod? 4.9 in Past Cadillac Vehicle Discussion; I pulled this Push rod out of my moms 92 Deville after she heard the engine start tapping yesterday. I ...
    seok's Avatar
    seok is offline Cadillac Owners Member
    Automobile(s): 1995 Deville 4.9, 1979 Eldo Biarritz 5.7 Carbed!!
    Nov 2010
    Oregon
    40
    56
    I pulled this Push rod out of my moms 92 Deville after she heard the engine start tapping yesterday. I pulled the Valve cover and noticed the rocker arm was loose so I removed it and pulled the Rod... heres what it looks like...
    Ive never gone any deeper into a 4.9 let alone MANY engines at all. ive done a few intakes, rockers, etc. but not on a 4.9.
    what do you guys think went on here??? Is it a straight fwd repair (pull intake, new lifter/rod)?? or is it worse than that?
    I have a FSM for our 94 Deville 4.9, hoping it wiill help me out with the 92 4.9.
    She loves her Cadi too much to let it go and is pretty bummed out about it so
    Im thinking positive here... any advice will be great guys!
    Matt
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Re: Help please! what happened to this pushrod? 4.9
    Is that the rocker end or the lifter end?
    seok's Avatar
    Nov 2010
    Oregon
    40
    56
    That's the lifter side.
    seok's Avatar
    Nov 2010
    Oregon
    40
    56
    Also, if anyone can tell me where to purchase the replacement parts from. So far im assuming I will need push rod and lifter. Along with any gaskets and other normal items.
    Slipgate is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Deville
    Jul 2009
    48
    710
    Looks like the lifter is bad. Which could mean the cam is also bad. Once you get a look at the lifter, let us know.
    seok's Avatar
    Nov 2010
    Oregon
    40
    56
    Ok, I should have the intake off this weekend. I hope the cam isn't shot... :-(
    seok's Avatar
    Nov 2010
    Oregon
    40
    56
    This is the first 4.9 intake I've removed. Is it pretty straight fwd? How much can I leave attached to the intake much and still lift off? Don't want to remove anything unnecessary.
    Oct 2004
    Oak Creek, WI
    5,607
    Very straightforward. I don't remember it being worth the effort to leave everything attached as it's all readily accessible anyway. That said, if you reall want to, I'm pretty sure you can leave the TB, EGR, and fuel rail on and remove it all as a unit with the manifold. Other major items in your way, not including little sensors and brackets, include the alternator (remove), PS pump/tensioner bracket (lines can remain connected, just unbolt and shift to the side), distributor (remove, obviously), valve covers, rockers, etc... Just remove anything in the way. No tricks.
    The only potential area of concern to the inexperienced is the rockers. You had to have touched this area to show us a picture of the pushrod, but I'll reiterate this anyway. These are mounted on a support bar that bolts onto the head studs. DO NOT attempt to remove the individual rockers as you would on a classic OHV engine. The pivot bolts are self-tapping, threaded into an aluminum bar. Risk of stripping threads is high. Instead, remove the bar and rockers as one unit.
    aeronca36606 is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Coupe Deville 4.1 V8 & 4.3 V6 Deisel & 1970 Eldorado
    Sep 2005
    East Tennessee
    773
    Allante's replaced this rocker mount bar with one made from steel. The Allante was expected to run in a higher rpm range more and they switched to steel from aluminum just for this reason.
    seok's Avatar
    Nov 2010
    Oregon
    40
    56
    Ok, got her torn apart and heres how the lifter looks....
    This is exactly how it was removed, the seat ( dont know the correct term) was out of wack and im guessing the push rod sunk down a little wich caused all the scoring and loose rocker arm. the bottom roller on the lifter looks nice and shiny, no marks of any kind, and looking down the hole the cam also looks smooth and shiny. im hoping this means everything is ok??? some professional advice and input would help me out alot since this is my first time working on the 4.9.
    Doing the waterpump while im here since i noticed a slight leak under the pump pulley. Could someone please stear me in the right direction to get EVERYTHING I need new to reassemble this?
    push rod
    lifter
    WP
    gaskets
    etc.
    69
    82,386
    WOW! Never saw a lifter like that. That certainly would explain the push rod. I would think it should be fine after replacing it.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    You can get a lifter from several different places, GM #17109057 about 30 bucks. The water pump if going for a new AC Delco is about down to dealer item, getting real hard to find from other parts stores resources. Reman can be bought from almost any of the parts stores but I wouldn't buy a reman, (just me as I prefer GM new pump and yes they are expensive). Push tube you are going to have trouble finding one new. If it were me I'd go to the salvage yard and grab a push tube. Not sure I'd buy a used lifter, but I suppose it would be OK if it were low mileage and I couldn't find one anywhere. Gaskets can be bought from most any parts stores or onliune sources. Go with the common brands like Victor or Felpro, should be ok with either. Use some ultra black for the ends of the intake in the corners and on the blocks on the top end under valve covers on the blocks. Look real close at all of the other lifters to be sure they aren't missing the ring at the top that holds the innerds together. Looks like the snap ring on that failed lifter came off. MAke sure you get the torque specs on reassembly as it is critical on rocker arm support, tightening sequence and torque. Same with intake manifold, don't guess get the sequence and torque spec. If you need those I can post up some images from the FSM for the asking.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,495
    Ouch. Usually there is a clip that holds that cap in the lifter in place so you might want to see if you can find it. If you can't find a new pushrod quicly you can probably reuse the old one but make sure it's straight and smooth out the scrapes. I've had a better luck with new aftermarket waterpumps then delco ones.
  16. #14
    Oct 2004
    Oak Creek, WI
    5,607
    Quote Originally Posted by brougham View Post
    Ditto, times 1000000.
  17. #15
    Feb 2010
    Orange County, CA
    62
    2,479
    There are several grades of Delco water pumps out there. Just because the box says AC Delco on it does not mean it is the better one.
  18. Remove Advertisements
