Results 1 to 7 of 7
Thread: GM cooling system tablets for Northstars or not...
    mutz is offline Cadillac Owners Member
    Automobile(s): 1996 and 2002 Cadillac SDV
    Dec 2007
    Toronto Canada
    74
    I was at a well established radiator shop today with my hot rod, in the Greater Toronto Area. I asked the owner of the shop what his opinon was regarding the tablets for North Star engines and he replied to me 'dont use the tablets but use a product called 'IRONTITE', it comes in a 455ml. plastic bottle and it's made by a company named Kwik Way Inc. (USA). He has used this product and claims that he has had excellent results. Check you automotive parts retailer, I got mine from Napa.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    Re: GM Tablest for North Stars or not...
    Cadillac does NOT recommend using any of that stuff
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by mutz View Post
    Exactly what do you expect this 'aftermarket solution in a bottle' to accomplish?
    Aftermarket products can claim whatever they can get away with; reading the fine print will reveal the limitations, conditions, and disclaimers.
    And the GM tablets were only intended to prevent nuisance external cooling system leaks. Nothing more.
  5. #4
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,842
    Here we go again.
    It would save a lot of time, space, typing and hand-wringing if we all simply said "Use whatever floats your boat".
    As posted, the difference between Bar's Leaks tablets #HDC or powder #G12BP and some sort of magic block sealer is more than night and day........ a lot more.
  6. #5
    69
    82,272
    Leave the snake oil on the store shelf (along with the tablets)!
  7. #6
    mike5514 is offline Cadillac Owners Enthusiast
    Automobile(s): 97sls,09dts
    79
    878
    If you do use irontite remove the lower radiator hose and add it there, if not there then the upper radiator hose. Dont put it in the surge tank! Mike
  8. #7
    crabgrass's Avatar
    crabgrass is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Deville
    Aug 2012
    Minnesota
    34
    142
    I was told by my Cadillac dealer where I purchase my pellets that the stuff was good at getting between dissimilar metals to prevent electrolysis. And it also calls for them right on the radiator housing tag. But I'm sure it work just fine without them.
  • You may not post replies
