stalling
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, stalling in Past Cadillac Vehicle Discussion; Ok fellas....just replaced fuel tank, pump, strainer, and filter.....baffle had broken loose. I can now kick down to passing gear ...
    glt6962 is offline Cadillac Owners Member
    Automobile(s): 1992 deville
    Jan 2012
    jackson, mi
    15
    stalling
    Ok fellas....just replaced fuel tank, pump, strainer, and filter.....baffle had broken loose. I can now kick down to passing gear with out it choking out as it used to but now I have erratic idle and it stalls every time I stop for a light....Help please....
    my best guess is (and forgive my lack of correctly articulating parts with exact terminology) throttle body position sensor or
    idle speed control...don't know if the following info is at all useful but I recently had a complete upper and lower rebuild done.......due to some clacking in the upper end and what was diagnosed as a mild lower bearing knock....its a 1992 deville...and
    Yeah some people told me they thought the rebuild was premature but I don't believe in the word mild when it comes to a
    lower bearing knock especially when it involves my freaking caddy motor...anyway any help would be greatly appreciated
    Brough is offline Cadillac Owners Member
    Automobile(s): 1988 Brougham
    Aug 2012
    Maine
    47
    80
    Re: stalling
    Not a lot of help here, but you'll probably get more responses if you put the year model and engine in the title. Do you have a dealer service manual? The diagnostic procedures are usually very thorough and they can be had cheap on ebay.
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    30
    769
    Re: stalling
    Check for a vacuum leak. that will cause an idle issue.
    Jan 2012
    jackson, mi
    15
    Re: stalling
    I did put on my post year being 1992 and model being deville...they made only one motor for this year and model 4.9
    Jan 2012
    jackson, mi
    15
    Re: stalling
    thanks...I have tried squirting starter fluid near all vacuum lines near throttle body....no change in rpms...is there another method?????
    Aug 2012
    Maine
    47
    80
    Re: stalling
    Some of the more pricey I've seen. You can get them new at Helminc.com also. Indispensable for this sort of thing.
    http://www.ebay.com/sch/i.html?_nkw=...5&_osacat=6029
    You didn't mention if your check engine light is on. I suspect the sensors you mentioned should have tripped a code.
    mjs182004's Avatar
    Dec 2008
    Eastlake, Ohio
    30
    769
    Re: stalling
    You can run an unlit propane torch with the valve cracked open over the suspected hoses while your engine idles. If you pass it over a hose and it idles up and take the torch away and it idles down. Also, try asking in the FWD Deville section. They will have more knowledge with your car. As this is the RWD section.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    Re: stalling
    the very FIRST thing you should ALWAYS do -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Dirtywaterdiver's Avatar
    Dirtywaterdiver is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Convertible
    Jul 2010
    Boston MASS
    268
    Re: stalling
    Mine did that.
    Had the smallest of leaks at the back base of the carb at the intake.
    Took 3 sprays before it did it.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: stalling
    Check out all the ISC threads here and verify that yours is working correctly. Make sure the EGR tubes under the throttle body are clean too. Maybe the codes will point you in the right direction too.
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Like Basscatt said try and see if you can pull any codes and post them with their meanings.
  14. Remove Advertisements
