05 cadillac deville rear window help
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 05 cadillac deville rear window help in Past Cadillac Vehicle Discussion; My rear window wont open or close while the door is closed, but if I open the door it opens ...
    scrappy281 is offline Cadillac Owners Member
    Aug 2012
    16
    My rear window wont open or close while the door is closed, but if I open the door it opens and closes perfectly. Does anyone know why this happens? Also, when the ac is on in the back, it sometimes blows warm air when its supposed to be cold, has this happened to anyone, too?
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,759
    Re: 05 cadillac deville rear window help
    For the window not opening when the door is open, sounds like the wiring harness to the door is stretched enough to where it's not contacting where it should when the door is open. Check the wiring into your door.
    For the warm air, I'm not entirely sure. I'll let the more experienced members chime in. My first guess would be that that a blend door in the ducting isn't working.
    Welcome to the forums BTW. You came to the right place for DIY help.
    69
    82,180
    Quote Originally Posted by scrappy281 View Post
    Pull the DTC's. Post them AND their definitions.
