Results 1 to 6 of 6
Thread: After 40 mph seems like transmission disengages
    phut7 is offline Cadillac Owners Member
    Automobile(s): Cad-Deville 1991 4.9L 300K miles
    Aug 2009
    74
    Good day. Several months ago the trans seemed to stutter a little when going from 40 to 50. While driving when car gets to 40 mph. Seems like the trans. disengages/slips. I put into 3 and it goes fine. This happens mostly when car is cold but can after running for a while. Fluid level is ok. I have code
    E91 . Please help where do I begin?
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,748
    Re: After 40 mph seems like transmission disengages
    Based on your codes and a quick bing search, it sounds like your Park/Neutral Safety switch is bad. If you plan on doing this yourself, it'd be a great idea to get a Factory Service Manual (FSM). Ebay is your go-to-guy
    Aug 2009
    74
    I think the way to check if it is bad is that the car will not start in Neutral correct
  5. #4
    Jul 2010
    Wyoming
    26
    5,748
    I think so, but I'm not entirely sure. I've seen a vid on youtube where the car will only start in neutral. You will want to check your wiring first though, and make sure that it's snug. I'm just going off the code your car has, and what I've read the code's definition to be. The wiring may be at fault, tripping a code for the switch. That's what happened with my transmission. Coded for a sensor, turned out to be a wiring harness.
  6. #5
    Aug 2009
    74
    Ok I will investigate.
  7. #6
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Clean your grounds, should be one close to your trans.
  • You may not post replies
