rear left window
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, rear left window in Past Cadillac Vehicle Discussion; i replaced the regulator and motor now the window still wont go up and down all i here is a ...
    cool twan72 is offline Cadillac Owners Member
    Automobile(s): 2000 deville dhs
    Sep 2012
    annapolis maryland
    44
    52
    rear left window
    i replaced the regulator and motor now the window still wont go up and down all i here is a clicking sound n the module.
    can anyone tell me what the problem may be
    redoxy is offline Cadillac Owners Fanatic
    Automobile(s): 03 DHS, 2008 DTS
    Aug 2011
    Edmonton, AB
    33
    148
    Re: rear left window
    I had a similar problem and others have too.
    the biggest culprit is the wiring going into the pillar. chek and recheck you will definitely find one that is broken. mine was actually broken on the connection going into the door. you have to move the black plastic cover far back to see. mine was the orange and black colour wires.
    Sep 2012
    annapolis maryland
    44
    52
    i'm going to try that thanks
    Sep 2012
    annapolis maryland
    44
    52
    i did the window and it was to wires broken put them back together and the window works fine now my trunk and gas tank wont open can anyone help with that problem
    Aug 2011
    Edmonton, AB
    33
    148
    Quote Originally Posted by cool twan72 View Post
    Does the trunk open manually? and do you hear a click when you use the remote or hit the trunk release button on the left?
    Again a very common problem. And this time also it is a wiring issue. On the trunk lid (left side) if you remove the carpet on the trunk lid and remove the black plastic strip on the hinge you will see a bunch of wires along there going into the back seat area. You will most likely have a broken wire there. Again check and recheck.
    Sep 2012
    annapolis maryland
    44
    52
    ok i will try that and you said behind the seat or in the trunk it self
    Aug 2011
    Edmonton, AB
    33
    148
    Like the responses to your thread on gas tank and trunk. First check to make sure your valet switch is off.
    If its off and you still have the problem then follow th wiring in the trunk on the driver side the wiring will be on hinge after you remove the carpet and the plastic cover on the trunk hinge
    Sep 2012
    annapolis maryland
    44
    52
    ok my valet switch is off i will try the wiring
    Sep 2012
    annapolis maryland
    44
    52
    tried to find a broken wire in the trunk but didn't find anythink could it be something else to make my gas door and trunk open
  12. Remove Advertisements
