what does the computer look like and where is it on a 91 deville - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 58 of 58
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, what does the computer look like and where is it on a 91 deville in Past Cadillac Vehicle Discussion; Thats i i dont get though if the wires are in the right place how com it does all that ...
  1. #46
    91deville1st is offline Cadillac Owners Member
    Jun 2012
    73
    Thats i i dont get though if the wires are in the right place how com it does all that if the position isnt that critical?
  2. #47
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: what does the computer look like and where is it on a 91 deville
    When I saw the distributor was not in the correct position, that told me your mechanic either does not care enough to get educated on your care and who knows what else was not done right. I don't know if he even did the timing the correct way. You need more than just a timing light. You also need to know how to set the timinbg and what it should be set at. I think you should find somebody that can do the job correctly.
  3. #48
    Jun 2012
    73
    Yeah he kept stressing that he had a lot of work to do so i guess thats why he didnt care i do need a new one and will i need to buy a new disteibutor? Or can i just take out this one and just put it at that angle again with out turning the rotor? Is that possible? And will that fix my car? And sorry for asking so many questions just worried on how my car would be
  5. #49
    Jun 2012
    73
    distributor fixed at best position close to 45 angle and still lacks power
    I had another post earlier and well my distributor was put better and now car wont shut off but still lacks in power and what causes to have white smoke and what makes a car use more gas then what it should because this car has demolished a lot of cats
  6. #50
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: distributor fixed at best position close to 45 angle and still lacks power
    You should have continued with your other thread. Don't start a new thread. Maybe we can get a moderator to move this back to the old thread.
    Leaking fuel pressure regulator, and or leaking injectors can destroy a cat.
    Take the vacuum hose off the pressure regulator. If it is wet, the regulator is bad. Turn the key on with the engine off, vacuum hose off, there should be no gas coming from the pressure regulator whare the hose was.
    Get a fuel pressure gauge and check pressure with key on engine off. How much pressure do you have on the gauge?
    Turn the key off and watch the gauge. Does the pressure drop all the way or does it hold pressure?
  7. #51
    69
    82,383
    Threads merged.
  8. #52
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    If the car won't shut off it sounds like a timing problem. I finally got to look at my distributor since your picture looked so familiar to me. My dist was installed just like yours but it ran fine. It always was a tight fit around the air cleaner though and I knew something wasn't quite right there. I probably wouldn't have bothered moving it unless I had another reason to remove it. Are you still getting all those codes? Are you sure you have the timing procedure correct?
  9. #53
    Jun 2012
    73
    To dennis how does the pressure regulator look like and sorry im a newby so i dont really know entirerly everything about cars and if it is wet like you said then thats the problem of using too much gas? And destroying cats?
  10. #54
    Jun 2012
    73
    To cadillac al , it did run fine? Like it has full power doesnt have that unsteady engine because when i start driving my hood is shaking and im not quiet sure if it still does ill recheck in the morning
  11. #55
    Feb 2010
    Orange County, CA
    62
    2,479
    It could be to answer both of your questions. Here's a couple pictures that should help you.
  12. #56
    Crudsturbo is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Seville STS & 1991 Sedan Deville
    Jul 2012
    Richmond, VA
    40
    181
    Check the fuel pressure regulator first, with the key on you might see fuel coming out of it from where the vacuum hose is. Start it up with the hose off and see if fuel comes out. If it does replace it. It isn't hard to change with the fuel rail off but it is a little tricky with the rail still on the car.
    Also the white smoke you are seeing is raw fuel most likely. Also check your oil make sure it isn't overfull. Recheck the codes, then clear them, then let it run and see what comes back.
  13. #57
    Jun 2012
    73
    ok i pulled new codes up and all codes excecpt e27 showed and i got two new ones
    E71-intermitted MAP sensor signal
    E74-inttermitted MAT sensor signal
    and next i will check the fuel regulator and what i do is unplug it turn on the car and if fuel comes out it is bad right??
  14. #58
    Feb 2010
    Orange County, CA
    62
    2,479
    Yes, where the vacuum hose goes on. Check your wiring harness whre the MAP sensor and MAT sensors are. I haven't heard of the MAT sensor going bad very often, sometimes the MAP goes bad. Beings those are intermittent, check engine harnes wiring and connections.
  15. Remove Advertisements
