what does the computer look like and where is it on a 91 deville - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 58
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, what does the computer look like and where is it on a 91 deville in Past Cadillac Vehicle Discussion; In my experience distributors (inside electronics) either fail completely or work fine; there is no middle ground of poor running. ...
  1. #31
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: what does the computer look like and where is it on a 91 deville
    In my experience distributors (inside electronics) either fail completely or work fine; there is no middle ground of poor running. My 92 ran fine without a cat with no codes. I think yours is something else.
  2. #32
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Quote Originally Posted by 91deville1st View Post
    Because i remember that there was this little screww rhat you tighten down a ground looking thing and is it possible hat since i got no cat that ita acting all retarded? Like no power and all that? And that i got flow masters on it?
    If you don't have a cat on it, then most likely you don't have a restriction. Post a picture of what you did in the distributor, otherwise it would just be guessing.
  3. #33
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    how many times can you beat a dead horse??????????????????
    Apparently...... ALOT
  5. #34
    91deville1st is offline Cadillac Owners Member
    Jun 2012
    73
    Does it make a difference that mine has the flowmaster and alows more exaust and that its a stock motor no adjustments?
  6. #35
    Jun 2012
    73
    IMAG0367.jpgIMAG0368.jpg this is how my distributor is now i sure its in a different position like there the 1st nd 8th plug is at
  7. #36
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,682
    what method did you use to set the ignition timing after swapping out the distributor -
  8. #37
    Jun 2012
    73
    Well the guy who did it had the lite to time it
  9. #38
    Jun 2012
    73
    What happens too is that i be getting white smoke really offten
  10. #39
    Jun 2012
    73
    What happens offten too is that white smoke come out
  11. #40
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    you be getting white smoke really offten from what -
    and is it smoke or steam -
  12. #41
    Jun 2012
    73
    Honestly idk comes from the exaust smells like gas is it bad? Ans is the position of my distributir supoose to be in the same original place from the old one or is it ok like that? Since its been timed
  13. #42
    Feb 2010
    Orange County, CA
    62
    2,479
    Nope, it should be at about a 45 degree angle. And I am telling you that because that is the way it says it should be in the FSM. I'm sure it's been suggested to you to buy a FSM. Right? Look at the picture below, do you have the wires in their correct location?
    Look at the position of the distributor in the picture below, that is how yours should be.
  14. #43
    Jun 2012
    73
    I will put it in its right position and no the didnt recomend me to buy crap these people do not help me i ahould of gone to yall before i switched it and buy it so aftwr i get it fixed right will it all be fixed?
  15. #44
    Jun 2012
    73
    Ans the mechanic that i went to did not even try to take it out and put it right will i have to buy a new distributir?
  16. #45
    Feb 2007
    Maine
    55
    3,310
    The exact position of the dist isn't 100% critical, it just shows that somebody doesn't pay attention to detail. As long as the wires are in the correct order it should run fine. If being out of position causes the plug wires to be out of position in relation to the numbers, then that is a small problem that should be corrected. It's Monday morning and I can't think straight yet.
  17. Remove Advertisements
