air ride compressor trouble
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, air ride compressor trouble in Past Cadillac Vehicle Discussion; i have an 86 fleetwood coupe and I changed the rear struts and the car never went back up but ...
    patwfc17's Avatar
    patwfc17 is offline Cadillac Owners Member
    Automobile(s): 86 fleetwood coupe
    Apr 2011
    8
    i have an 86 fleetwood coupe and I changed the rear struts and the car never went back up but it always sat low so I'm not sure how long it didnt work for then a went to a junkyard and get a diffent compressor an it still didn't work and now I have no idea what to do
    please help
    thank you
    68
    81,883
    Re: air ride compressor trouble
    Have you checked the fuse? Are you sure that the junkyard compressor works?
    patwfc17's Avatar
    Apr 2011
    8
    thanks ill check the fuse i got this car from my grandma and dont no that much about it
    patwfc17's Avatar
    Apr 2011
    8
    do u no what fuse to check
    68
    81,883
    No, but if you pull the fuse cover there is usually a diagram in it. Should also be one in your owners manual.
  8. Remove Advertisements
