Whats it worth?
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Whats it worth? in Past Cadillac Vehicle Discussion; My brother bought a 1999 Deville D' Elegance yesterday for $750 bucks. 90,558miles and runs great we put a radiator ...
    Crudsturbo is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Seville STS & 1991 Sedan Deville
    Jul 2012
    Richmond, VA
    40
    181
    Whats it worth?
    My brother bought a 1999 Deville D' Elegance yesterday for $750 bucks. 90,558miles and runs great we put a radiator in it because the person who put the last one in didn't set it back right right and the fans were cutting holes in it. He is concerned about the head gaskets per horror stories he has read. But all in all the car is in outstanding shape. Tepmature goes up to about 240 at times but he says runs at 210-215 most of the time. Fans dont kick on until 227 or higher.
    Also if it does need head gaskets down the road is it really that bad of a job. He is an outstanding mechanic who builds forklift engines and has not in 8 years had a single issue from any motor he has built. He says he is 100% familiar with the open deck setup and says even those if done right can hold up if done right. I know from using this forum that you guys are on right on with information and and words of wisdom here would be great.
    He was skeptic to buy a cadillac but he loves everyone I have ever owned (lol so far only 3). I fell in love with the brand when I had my first 93 Sedan Deville and regretted it every day since I sold that car. I however love the 4.9 although I am not scared of the Northstar like so many people cringe when you say the name.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: Whats it worth?
    For $750, I'd say just drive it and enjoy it. IF you end up with head gasket issues, you're not really out that much. I wouldn't spend $2500 - $3000 to fix a $750 car, though.
    240 does seem a bit too high. Have you done a block test?
    68
    81,883
    Re: Whats it worth?
    The '99 is the worst year for HG failures for some reason. If they need to be replaced he will have to drop the drivetrain to drill, retap and install the inserts or studs and then replace the Hgs.
    That 240 degree temperature "at times" is not a good sign.
    Jul 2012
    Richmond, VA
    40
    181
    Re: Whats it worth?
    A block test was performed on it a few months ago and supposedly passed but it wasn't us that did it. The girl had it here at the shop I acquired and was asking 2500.00 for it with a bad radiator. She was also told that the head gaskets were replaced but I am positve they were not. IT came in for overheating after a radiator was installed. We put one in and it was a matter of installing it correctly so the fans didnt rub a hole in it.
    Could he use a fan controller to have them on more to help with cooling? Just doesnt seem that they come on when they should. He uses one of these for his 78 chevy electric fan.
    Also is it really 2500-3k just for Head Gaskets? Mind you he is the one doing the labor so thats not a cost factor.
    68
    81,883
    Re: Whats it worth?
    Quote Originally Posted by Crudsturbo View Post
    That is a band-aid that will just prolong the inevitable. Fans should come on at 224. 3 degrees should not make that much difference, assuming that your 227 is accurate.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,830
    Re: Whats it worth?
    crudsturbo, As you already know from reading all the threads in here, Northstar Performance, and Cadillac Tech Tips fans go to Slow at ~224, fast at ~236 and run in Slow any time an A/C function is set. 240 is hot, and 265 is overheated. The design thermostat begins at ~188 and is fully open at ~206. The engine should run at 195 - 205 degrees at all times except when stuck in traffic with no A/C function set; then it will go to 224, fans come on and cool to 213, fans OFF, cycle starts over. normal
    If the engine and cooling system are in good condition ANY of these cars has absolutely no trouble maintaining design coolant temps in any ambient temperature on earth. If it won't, then something major is wrong, and band-aids won't fix it.
    Jul 2012
    Richmond, VA
    40
    181
    Re: Whats it worth?
    Quote Originally Posted by Submariner409 View Post
    Yes I was getting the information of when they come on and speed from here. And agreed that if designed like that than it should cool. How accurate is the digital tempature guage? We found the thermostat was sticky so he replaced it and still same temp issue. We are worried that 240 is high and you confirmed our worry.
    68
    81,883
    Re: Whats it worth?
    The digital temperature readout should be pretty accurate.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,340
    Re: Whats it worth?
    check the PURGE LINE for proper coolant flow
  12. Remove Advertisements
