Question regarding replacing water pump on 96 DeVillle 4.6L
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Question regarding replacing water pump on 96 DeVillle 4.6L in Past Cadillac Vehicle Discussion; Going to replace the water pump on my 96 Deville 4.6L............I am aware of the new O ring that has ...
    CaptainDeville is offline Cadillac Owners Member
    Automobile(s): 96 Sedan DeVille 4.6L
    Apr 2008
    McHenry County, Illinois
    21
    Going to replace the water pump on my 96 Deville 4.6L............I am aware of the new O ring that has to be replaced. Should that O ring be lubricated with Lithium grease?
    Also, The Haynes Manual (for what it's worth) makes no mention of a gasket. Some of the auto parts sites show a gasket included and some don't. If a gasket is supplied, what
    kind of adhesive should I use and do I apply this adhesive to both sides of the gasket. I already have the special GM tool to remove the pump. Thanks for any help with this
    fix.
    69
    82,383
    Re: Question regarding replacing water pump on 96 DeVillle 4.6L
    Hi neighbor
    You can use a little grease or petrolium jelly to hold the O ring in place if you need to. Otherwise no lube or adhesive is required on it or the cover gasket.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    High neighbor
    Is that due to elevation differences, or use of illicit substances?
    69
    82,383
    No, it was due to head up ass. Corrected. Thanks.
    Apr 2008
    21
    Thanks Ranger........appreciate your advice
  8. Remove Advertisements
