Brake problem - 1992 Deville with soft pedal
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Brake problem - 1992 Deville with soft pedal in Past Cadillac Vehicle Discussion; replaced the master cylinder and wheel cylinder have bleed breaks still almost gooes to the floor but the breaks seems ...
    old tin man is offline Cadillac Owners Member
    Automobile(s): 92 deville
    Aug 2012
    62
    12
    replaced the master cylinder and wheel cylinder have bleed breaks still almost gooes to the floor but the breaks seems to work that sound right
    68
    82,048
    Re: break prob
    No, that is not right. If you can pump the pedal up, you still have air in the system someplace. Did you bench bleed the MC?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,466
    Re: break prob
    did you "bench bleed" the master cylinder BEFORE you installed it?
    if you didn't - there is air trapped in the master cylinder -
    and because of the mounting angle - you will NEVER get the trapped air out -
    you can bleed GALLONS of brake fluid through the system -
    and use EVERY method of bleeding - it just ain't gonna work -
    you will need to remove the master cylinder - and bench bleed it -
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    Re: break prob
    wow,,,,that seems like a pain in the b)&$.
    rodnok01's Avatar
    Feb 2012
    NC
    6,649
    Re: break prob
    Verify is was the correct bore MC also....
    Def bench bleed before also.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,466
    Re: break prob
    Quote Originally Posted by blalockchiro View Post
    what - the bench bleeding?
    it only takes a few minutes to do - but is absolutely critical
    Aug 2012
    62
    12
    Re: break prob
    so if i take the master cycinder off and bleed it it should it work
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,466
    Re: break prob
    Quote Originally Posted by old tin man View Post
    IF there is air trapped in the master cylinder -
    and you remove it - and bench bleed the air out -
    you should get a "normal" pedal after you reinstall it and bleed the system -
  11. Remove Advertisements
