1994 Deville Heater Core
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1994 Deville Heater Core in Past Cadillac Vehicle Discussion; This is my first time using a forum. So please bear with me. I'm trying to install a new heater ...
    GALEN2002 is offline Cadillac Owners Member
    Automobile(s): 1994 DEVILLE
    Aug 2012
    44
    5
    This is my first time using a forum. So please bear with me. I'm trying to install a new heater core. I have a Chilton book but it has no pictures or diagrams for this job. I was wondering if anyone out here has detailed pictures or diagrams for removing a heater core. If so could you please send to my email at g_mack2002@yahoo.com
    Thank you very much
    Also you can insert in this post the diagrams
    Thanks again
    68
    81,914
    Re: 1994 Cadillac Deville Heater Core
    Haynes (and Chiltons) are rather useless for anything but the most basic of repairs. You really need a FSM by Helm Inc. Ebay is your friend.
    Check the Tech Tips section. You might find something in there.
    Not sure if this will help much.
    http://www.gmpartsgiant.com/Page_Pro...-031&SortKey=7
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    ^^^^^ Like Ranger said, get the FSM. Your car takes 2 volumns. Here's a link to the books on ebay. I noticed there is a pair up for bid ending in 2 days for 15 or 16 bucks plus shipping. That is an excellant price if you are interested.
    http://motors.shop.ebay.com/i.html?_...506.m270.l1313
    94 sedan base is offline Cadillac Owners Member
    Automobile(s): 94 Deville 01 Deville DTS
    Jul 2010
    Central Ohio
    61
    I replaced mine a year ago & it wasn't bad.You have to remove it on the passenger side under the dash,be sure to remove the heater hoses from it prior to getting it out.
    Aug 2012
    44
    5
    Thanks
    Aug 2012
    44
    5
    Update on heater core job. I paid a guy to help me with the heater core job. I think the heater core is in correct now air is not comin thru my vents. Can anyone help with some kind of detailed step by step pics so I can go back thru and see whats not connected
    Thanks
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Are you trying to get heated air through the dashboard vents?
    It won't happen. Heat comes out the floor and windshield area only. This is automatic and cannot be changed on a '94.
    That's assuming you set the temp on "90" to force the heat to come out.
    If air is not coming through the vents when its is set on "auto", then you do have a problem. Possibly a vacuum leak. Does the Automatic Park Brake release work?
    68
    81,914
    Aug 2012
    44
    5
    Thank you very much great pics. The pics for the heater core removal like this would really help me too
    frostycadillac is offline Cadillac Owners Member
    Automobile(s): 1968 DeVille, 1985 Seville, 1990 Deville, 1994 Deville,
    Oct 2009
    Tampa, Florida
    56
    43
    I replaced my heater core last year, unfortunately for no reason. It wasn't the heater core that was bad, it was the air door module that was bad. While you have things open under there, move your climate control from heat (anything above 80) then look at the top of the module under the passenger side dash. You will notice the arm on the air control door moving. Check it again when you move the climate control back to a colder temp to force the ac to come on. Also, a little tip, you can pull the codes from the computer using the climate control buttons by holding OFF and HEAT together at the same time, your car will cycle through PCM, IRC, and so on. Look up any codes that are current. If the air door is the problem, the computer will tell you. The FSM are like your Bible, I can't tell you how many times that book ends up in my bathroom!
  13. Remove Advertisements
