1991 Deville no coolant in oil, but oil in coolant?
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1991 Deville no coolant in oil, but oil in coolant? in Past Cadillac Vehicle Discussion; No coolant in the oil, but oil in the coolant and it runs a little rough? I'm guessing that this ...
    xeph is offline Cadillac Owners Member
    Automobile(s): 1991 deville
    Aug 2012
    1
    No coolant in the oil, but oil in the coolant and it runs a little rough? I'm guessing that this is a blown head gasket or cracked head (opinions?). But sadly, I'm not a mechanic. I love this car, everything works and it runs for like 15 minutes at a time without running hot. My question is, I only paid $900 for the car (I will also need to fix the suspension down the road). Is it worth the money to fix it or should I just resell it as-is? It only has 165000 original miles. I've heard that I could use "Blue Devil" as my commute is under 10 miles a day, but am fearful of a sealant. Even an expensive one.
    Any help is greatly appreciated
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: 1991 Deville no coolant in oil, but oil in coolant?
    Quote Originally Posted by xeph View Post
    [I]No coolant in the oil, but oil in the coolant and it runs a little rough? I'm guessing that this is a blown head gasket or cracked head (opinions?).
    Oil in coolant tells me failed engine oil cooler in radiator tank on drivers side. Think of it this way, oil pressure is higher than coolant pressure. Problem is that coolant will eventually get in oil pan when the engine is shut off, then coolant pressure is higher than no oil pressure. I would make sure that is what your problem is before you dump $60.00 worth of blue devil in it, (I wouldn't even use that nasty stuff), and besides blue devil WILL NOT FIX YOUR PROBLEM with oil in the coolant.
    Sounds like it might need a tuneup to fix the rough running issue, plugs, throttle body and EGR tubes in the intake manifold cleaned. What is wrong with the suspension? If it is the rear struts leaking air, those can be replaced for a reasonable amount. I bought some Monroe Sensatrac with the air bladder on the shock, they have a less expensive economy version also. Check out Amazon or rockauto.com several other places also.
    Last but not least read the sticky at the top of the page How To Pull Codes, pull your codes look up the definitions, post back your codes AND their definitions.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Bad head gaskets results in exhaust gas in the coolant and/or coolant in the exhaust (cylinders). You could also get coolant in the oil, but not oil in the coolant.
    68
    82,070
    I'm with Dennis. Side tank oil cooler. Replace the radiator.
    Blue Devil
  7. Remove Advertisements
