Engine problem 1995 Sedan Deville
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Engine problem 1995 Sedan Deville in Past Cadillac Vehicle Discussion; I have a 1995 Cadillac Sedan Deville 4.9 Engine . All of a sudden it wouldn't start. I replaced the ...
    SkylerV is offline Cadillac Owners Member
    Automobile(s): 1995 Sedan Deville
    Aug 2012
    I have a 1995 Cadillac Sedan Deville 4.9 Engine . All of a sudden it wouldn't start. I replaced the inline fuel filter, still no gas getting
    to the filter, so I replaced the fuel pump. Still no gas getting to filter from gas tank. I put some gas in the carbuator area and it started right up. Then when the gas as used it stopped running and would not start. What else could it be? What can I try now.
    Please;;;;;; I need help. Have to get to work.................................thank you everyone
    68
    81,740
    Re: Engine problem 1995 Sedan Deville
    Sounds like the pump is not pumping. Check the fuel pump fuse.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,844
    Can you hear the fuel pump run when you turn the key to on?
  5. #4
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    http://www.cadillacforums.com/forums...x-engines.html
    Try checking your codes and see what comes up.
  6. #5
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Did you check the fuse to the fuel pump , did you check power and ground wire at the pump?
  7. #6
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,477
    Check the power to the fuel pump, it might be a gray wire. There should be a fuel pump prime wire connector somewhere under a fuse panel possibly under the hood that you can provide power to determine if the wire is good to the fuel pump. You also have a relay that provides power to the fuel pump. You almost need a wiring diagram to determine source of power and what makes your fuel pump run.
  8. #7
    Aug 2012
    Yes pump works. We think it is a fuel line to inline fuel filter
  9. #8
    Feb 2010
    Orange County, CA
    62
    2,477
    Check line from filter to engine also, I've seen a couple with a kink just above the filter.
  10. #9
    Feb 2007
    Maine
    55
    3,310
    I was thinking it had fuel but wasn't injecting it. It sounds like it actually has no fuel pressure after all. If you put a new pump and filter on it then the fuel lines must be ok. It must be the power to the pump.
  11. Remove Advertisements
