Leaking tranny fluid
Results 1 to 15 of 15
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Leaking tranny fluid in Past Cadillac Vehicle Discussion; I just came back from my road trip last night and when I went to leave for work this morning ...
    BLMDeville is offline Cadillac Owners Fanatic
    Automobile(s): 95 deville 4.9
    Mar 2012
    29
    114
    I just came back from my road trip last night and when I went to leave for work this morning I noticed a puddle of tranny fluid under my car.
    I was wondering what I should look for when trying to find the leak.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Leaking tranny fluid
    The lines and or hoses going to the cooler. I hope you either didn't drive it or at least checked the level on the stick.
    Mar 2012
    29
    114
    I foolishly drove to work I have some fluid in my trunk i'm going to add a little after work. Should I warm the car up check it add a little go for a ride and check it again?
    Also how much would you add from the bottom of the dip stick so I can get an idea of how much to add?
    Is it a quart like the oil?
    The thought of my tranny doing anything other than what it's supposed to do is quite terrifying.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,368
    do NOT add any trans fluid until you check the level -
    there is a transmission dipstick -
    to check the trans fluid level -
    the car needs to be on level ground -
    the engine needs to be be at normal operating temperature -
    the engine must be running -
    the transmission in PARK -
    pull the dipstick - and wipe it off -
    insert the dipstick - and pull it out - look at the level -
    if the fluid is LOW - at or below the ADD mark - add some trans fluid -
    the fluid is poured down the same tube the dipstick goes into -
    Mar 2012
    29
    114
    Ok I checked the tranny fluid and it is at the same level as it was when I left to come home. So i'm more inclined to think it could be oil or power steering fluid. The puddle was close to the pully side of the motor. It's raining like crazy out today so i'm going to try to put cardboard under the car tonight like it says to do in the FSM to try to get a better idea of where it's coming from and exactly what kind of fluid it is.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    If the oil drips are coming from the front side of the engine, slightly to your left when looking down on the radiator it's either engine oil from the filter, pressure sending unit, or oil filter adapter O-ring seals.
    If the drips are more toward the "belt end", radiator side or firewall side of the engine, that's P/S fluid.
    Feb 2010
    Orange County, CA
    62
    2,479
    Sub, he has a 4.9 oil filter is towards the rear, usually runs down between the engine and trans. Pressure switch is next to the filter.
    Mar 2012
    29
    114
    I just replaced the oil pressure switch neither the oil filter housing or the two oil cooler lines are leaking.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Sounds like PS fluid to me.
    Instead of cardboard, use white paper. This makes it easier to see the color.
    Black to dark brown - engine oil
    Red - trans fluid
    Clear - PS fluid (or brake fluid)
    Green or orange - coolant
    LeaderX11's Avatar
    LeaderX11 is offline Cadillac Owners Fanatic
    Automobile(s): Deville 2004
    Sep 2011
    26
    121
    I ws thinking that P\S uses the same type of fluid that used for transmission .....
    Feb 2010
    Orange County, CA
    62
    2,479
    No, P/S uses P/S fluid. Should be clear, but can be brown. Very few people bother to change it or flush it out.
    onecool is offline Awaiting Email Confirmation
    Dec 2005
    288
    I have seen power steering fluid come in red and I have seen people use transmission fluid as well in power steering units.
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    44
    1,845
    Ford did that for a while. I once had a '77 Mercury that used tranny fluid for the power steering.
    I don't know if they still do.
  16. #14
    68
    81,917
    Years ago trans fluid was used in the P/S pump. Not sure if that still holds true today.
  17. #15
    LeaderX11's Avatar
    Sep 2011
    26
    121
    Wow, this makes me happy for a while ,,, I think that I the only one with GM vehicle who still uses trans fluid for steering !!!!
    oh well, I think now I got the reason for steering stiff in very low speed turning !!!
  18. Remove Advertisements
