Power Steering stiffness solved!
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Power Steering stiffness solved! in Past Cadillac Vehicle Discussion; Hi Let me share my story in hopes that it will help others out there with the same problem I ...
    aespino is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Deville
    Jul 2007
    25
    Hi Let me share my story in hopes that it will help others out there with the same problem I had with my 2001 Deville. About a eight months ago my power steering started to get stiff with low RPM's about 625 to 700 (specially on stop lights). I thought it was the fluid so I changed it. I still had the problem so I decided to change the power steering pump after 50K maybe it was on its way out. I installed the new pump but still had the same problem. After doing research on the this forum and other places on the web I came to the conclusion that it had to be the steering rack. While working on installing the new power steering pump I notice that the drive belt was kind of loose but didn't much attention to it I was more worry about the steering problem. Later that day I started working on Pontiac Bonneville and notice that the belt tentioner was not as easy to move as the Deville's. So I started to compare both the tentioners and the belts. Then I also notice that The Deville's belt was making more noise that it should. So I decided to get a new belt and tensioner. I installed them both brand new and to my very happy surprise the problem was completely gone! To doble check and since it's not difficult to do I reinstalled the old pump and the power steering worked perfectly, so the problem definitely came from the belt and tentioner.
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    64
    347
    Re: Power Steering stiffness solved!
    Good post. This kind of stuff is always good to know.
    My power steering was a little stiff. But the belt was fine. I ended up changing the fluid by suctioning out the reservoir. I did this about five times so far. I have been re-filling with Royal Purple synthetic P/S fluid, and the steering has gotten noticeably smoother and easier.
    LeaderX11's Avatar
    LeaderX11 is offline Cadillac Owners Fanatic
    Automobile(s): Deville 2004
    Sep 2011
    Saudi Arabia
    26
    121
    Mine also stiff under turning with very low speed and while the car not move .....
    Thanks I'll check the belt .... I know that it's never replaced so far ....
    Jul 2007
    25
    Remember also to check the belt tentioner
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,220
    FWIW, also change the water pump drive belt tensioner pulley - if that goes you're in for a nasty repair job because it WILL take out the intake cam water pump drive pulley as well as the belt.
  8. Remove Advertisements
