Cadillac Deville 2000,check coolant level
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Cadillac Deville 2000,check coolant level in Past Cadillac Vehicle Discussion; My car has no problem like this before I changed the coolant 'now sometimes message comes check the coolant level ...
    imran76 is offline Cadillac Owners Member
    Jul 2012
    10
    My car has no problem like this before I changed the coolant 'now sometimes message comes check the coolant level whenever I turn on my AC message comes like after 5 mins'so I press the info button and it disappeared, is there any solution for that,,,
    69
    82,162
    Re: Cadillac Deville 2000,check coolant level
    Is it in fact low on coolant? Proper level is about 1/2 full, no lower. If it is at the correct level, then it's probably a bad level sensor in the surge tank. You'll have to replace the tank.
    LeaderX11's Avatar
    LeaderX11 is offline Cadillac Owners Fanatic
    Automobile(s): Deville 2004
    Sep 2011
    Saudi Arabia
    26
    121
    I faced this problem last year,,, and every time the message show up , I check for the coolant level ,,,, and it always at the proper level ....
    One time when the message came out I seen a mid size mouse playing with wires . After that bad friend went out the problem also went out ....
    Do you know that bad friend traveled with me 212Km !!!!!!
    Until now I can not imagine how he still in one peace inside the FWD NorthStar high temps engine bay !
    Jul 2012
    10
    I always check coolant always full,a local mechanic told me it might be air bubble I don't know'if its a bubble how to get rid of that
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    It's not an "air bubble" - the coolant reservoir should be about half full, cold. NEVER check or adjust coolant level when hot. If the coolant is at the proper level, cold, and the message returns, there's a problem with either the level sensor or its wiring.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,561
    there is a float type switch/sensor in the coolant serge tank -
    the sensor is not serviceable -
    you could try flushing the tank with a garden hose -
    but 99% of the time - the serge tank must be replaced -
    the dealer wants over $175 for this part -
    you have a couple of choices -
    get a new aftermarket DOORMAN brand part - $65.73 with FREE shipping -
    http://www.amazon.com/Dorman-603-122-Coolant-Recovery-Kit/dp/B003S5XCDQ/ref=au_pf_pfg_s?ie=UTF8&Make=Cadillac|46&Model=DeV ille|406&Year=2000|2000&carId=001&n=15684181&newCa r=1&s=automotive&vehicleType=automotive
    OR - get the original delco part #25774005 - for $69.92 - with FREE shipping -
    from autopartstomorrow - through Amazon.com
    http://www.amazon.com/gp/offer-listi...&condition=new
    the part is not hard to change
    RustyBlazerDude's Avatar
    RustyBlazerDude is offline Cadillac Owners Fanatic
    Automobile(s): 2010 EXT, 2001 DTS
    Nov 2007
    101
    I too had similar problem with 2001. I just shorted out the sensor with a paperclip i think to make the message go away for good.
    Cooling system is closed so unless you have a leak, you should not lose fluid. An eye on the temp gauge and a peek at the reservoir every once and a while is good enough for me.
    Of course, best thing to do is change the sensor as basscat mentioned above.
    Jul 2012
    10
    Thanks guys
  11. Remove Advertisements
