Brake Problem
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Brake Problem in Past Cadillac Vehicle Discussion; my breaks began to go to the floor .i added fluid still goes the floor where the fluid go .i ...
    old tin man is offline Cadillac Owners Member
    Automobile(s): 92 deville
    Aug 2012
    63
    12
    Brake Problem
    my breaks began to go to the floor .i added fluid still goes the floor where the fluid go .i have checked for leak tires and mastercylinder any idea thanks
    69
    82,402
    Re: breaks
    If the pedal goes to the floor and there are no external leaks, the master cylinder is leaking brake fluid internally past the piston. Time for a new master cylinder.
    P.S.
    I retitled your thread.
    Aug 2012
    63
    12
    Re: Brake Problem
    but wherse the fluid going
    69
    82,402
    Re: Brake Problem
    No where. It is staying inside the MC, but passes around the piston, thus the pedal slowly sinks to the floor. Imagine an engine with pistons, but no piston rings. Where would the air being compressed in the cylinder go?
    Aug 2012
    63
    12
    Re: Brake Problem
    i had to add fluid
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Brake Problem
    If you have to keep adding fluid, then you should see it leaking onto the ground somewhere. Did you look around the ABS valve? Pull the vacuum line off of your brake booster, is it wet from fluid or dry?
    Aug 2012
    63
    12
    Re: Brake Problem
    you talking about the hose on the side its about 3/4 black hose it had fluide in it... thanks for the help
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: Brake Problem
    Yeah that's it. Sounds like you need to replace that booster and master cylinder.
  11. Remove Advertisements
