2004 DTS limp home - cranks but will not stay running, only code P0102
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2004 DTS limp home - cranks but will not stay running, only code P0102 in Past Cadillac Vehicle Discussion; Hi team, got a dependable 130,000 mile daily driver- however, stopped at grocery store to pick something up on way ...
    cesully is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2007
    3
    Hi team,
    got a dependable 130,000 mile daily driver- however, stopped at grocery store to pick something up on way home from
    work and car would not stay running without me putting into neutral and maintain RPMs to get it home.
    Now it cranks and won't start - only code was P0102 - low MAF sensor low, would this cause my problem, i was
    thinking fuel pump...
    ran into this same issue intermitently in the past few months but it started again and was ok...
    can anyone advise me on a fix for this issue or do I tow to garage- hope not
    thanks,
    Craig
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Re: 2004 DTS limp home - cranks but will not stay running, only code P0102
    68
    81,745
    Fuel pump is a possibility. Only way to know for sure it to put a fuel pressure gauge on it. Probably ought to replace the MAF sensor as well.
  5. #4
    jmf1964 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville, Silver, 1972 Eldorado, 1974 eldorado, 1975 CDV
    Jun 2009
    boston mass or thereabouts
    52
    194
    The throttle body may need to be cleaned.
    My 2004 acted exactly the same way, would start and stall, start again and stall again. I had to keep one foot on the gas just to keep it running. Cleaned the throttle body and IAC passage, it's run like new ever since, this was a year ago.
    John
  6. Remove Advertisements
